Author Topic: new 2011 rule changes  (Read 103230 times)
Offline Avanti Kid
  • 2006 Member of Bonneville 200 MPH Club
Re: new 2011 rule changes
« Reply #330 on: January 02, 2011, 12:12:34 AM »
Years ago I replaced my glass lenses for my headlights with plastic lenses, and yes my head lights still have to work.  This should work better than safety film on the original glass lenses. Dave
Original owner of 1963 Avanti; Age 84
2006 Bonneville 200 MPH Club Member
Canyon Country, CA
215.6 mph 289 CI Studebaker engine
Offline dw230
« Reply #331 on: January 02, 2011, 12:56:25 PM »
Ron,
If you replace or cover the headlights with metal it has to meet the minimum requirements for class. Decal not necessary.
Dave,
Lights do not have to work in any class.
« Reply #332 on: January 02, 2011, 01:05:12 PM »
That had been a niggling concern in the back of my head since day one - thanks for that, Dan.  I trust horns need not be functional, either?
saltfever
« Reply #333 on: January 02, 2011, 03:57:18 PM »
That is correct. Pg 46, Paragraph 4.DD spells out street equipment that needs to be in place. However, it fails to mention it all can be non-fuctional.   A rule clarification that is long overdue.
Offline dw230
« Reply #334 on: January 02, 2011, 04:06:44 PM »
Don't you want to have any fun in impound? Left in that format because you and I need to open the rule book over something. You young guys need too much direction.
saltfever
« Reply #335 on: January 02, 2011, 04:17:40 PM »
Its more fun to open sumptin with a pop-top.  :cheers:
« Reply #336 on: January 02, 2011, 05:12:53 PM »
Speaking of direction - what about the turn signals?  :-D
Dan, I'd love to have a discussion in impound.  That means I would have made it to impound!  :cheers:
Offline Queeziryder
  • Former funnybike racer now Salt crew
    • G&N Racing
« Reply #337 on: January 02, 2011, 05:20:53 PM »
Ah
But Chris, the horn's good for telling people to get out they way before you run them over on the way to impound :-D
Neil
Old enough to know better, but too interested in speed to care
Offline 38flattie
« Reply #338 on: January 02, 2011, 07:22:45 PM »
Thanks Dan, For getting the rulebook wording clarified, and answering all the questions here on the board! :cheers:
Offline Avanti Kid
« Reply #339 on: January 02, 2011, 09:44:43 PM »
Yes, Dan thanks for the help!!  :cheers:
Canyon Country, CA
Offline Dynoroom
« Reply #340 on: January 03, 2011, 10:58:29 AM »
That just means you guys havn't been around long enough to remember that Production & Gas Coupe did require a working horn in the not so distant past....... why else have it in the book....... my, how times change.
Had to honk Geislers in '80 when Stringfellow got in.
« Reply #341 on: January 03, 2011, 01:28:41 PM »
  And don't forget the horn had to be able to start the engine :-o :-D
Offline jimmy six
« Reply #342 on: January 03, 2011, 09:38:47 PM »
Maybe I read all this wrong, but I can't find anywhere where all this "stuff" needs to work. When I converted my 40 Chevy from Altered to Gas Coupe in 1978 the rule book stated the same as does now. I needed to find a 1940 horn and attach it behind the grillle and search out a pair of fender mounted parking lights to make sure I met the rules for the class but I didn't make anything work. I had to add a front bumper and running boards too. Faked the bumper mounting brackets cause I couldn't find any but as for working I've looked at the latest rule book on pages 68, 69, 73-77 and only that you need them and they be the same year as the car.................................but I could be wrong...........JD
saltfever
« Reply #343 on: January 03, 2011, 10:19:25 PM »
You are correct JD. Nobody is saying that stuff has to be operational. See my post #333 above. That paragraph has never changed but the issue comes up quite often. It was raised on this forum a couple of years ago. The confusing thing is that it says “. . . required for legal street operation”. Almost all states require stuff to be operational in order to be legal street equipment. Who hasn’t gotten a fix-it ticket. :-D We know the text is just an all-inclusive way of making sure parts are there for aero purposes. Working or not is irrelevant. (Unless you have “wig-wag” turn signals). The decal change was added about 2 years ago and it would have been easy to clarify functionality then. But that would have resulted in a clearly understood rule. :evil:
Offline dw230
« Reply #344 on: January 04, 2011, 09:21:50 PM »
If you need the rule to state "non-functional" or whatever is needed to clarify, submit a change form.
