Hi Dan!
Where the rulebook says now:
"3.A.3 Driver’s Helmet SupportLateral Movement: The seat, roll cage structure or suitable restraint system, such as a restraint net, swing away bar or similar such device, shall provide restriction to lateral head movement of less than 2 in. per side inclusive of structure deflection, and at a minimum extend to the forward most portion of the helmet see Section 3.B.1."
I would like to see a little clarification on the part that says "head movement of less that 2 in. per side".
To me, that means that in the seated position, if you lean your head to one side, you should have 4" on the other side of your head.
When we built my car... I knew this was wrong... so I asked. I was told by a tech inspector that you should have about 2" to one side if your head is up against one side.
So, I think in this case... it would be good to have an example in there. i.e. "Example: If your helmet is against the padding on the right you should have x-amount of distance from the helmet to the padding on the left side."
Just a suggestion!
Sam
