As racers we seem to whine sometimes. But then as racers we think of a way to get around problems all the time. weather it's making more power from a small engine or making a stock body just a bit more aero.
The answer to this question has been around for decades........
It's called a water tank. Also note the rule only gives outside demensions, not thickness.
Oh, and as far as gas coupes go, I can point out many who use a stock size radiator..... some running over 1400 hp. Go figure.....
Mike, I am sorry you think I’m whining. I don’t want hot water in the cockpit! This creates an unnecessary safety issue.
This rule change is not an issue for bigger cars. Camaros, Firebirds, Mustangs etc all have very wide stock radiators regardless of core thickness. As you well know and mentioned 1,400 hp can be handled with core thickness and other tricks.
The issue is for smaller cars. Monza, Vega, Honda, Toyota, ect. They all use go-cart sized radiators. The rule is clear . . .
OEM dimensions means OEM area. All you can do is add thickness and in these small cars you can’t do that when stuffing in a bigger engine. You can’t do an engine set-back and you can’t cut sheet metal to be a legal gas coupe.
The rule is well intended but it creates very broad unintended implications.
