Author Topic: Shootout 2009  (Read 341611 times)
0 Members and 7 Guests are viewing this topic.
Re: Shootout 2009
« Reply #60 on: September 21, 2009, 02:33:43 PM »
George Poteet is suiting up at the 12 mile.  Winds are high again -- about 10-12 -- but straight down the track.  Speed Demon chase/return truck is about at the 2.
Re: Shootout 2009
« Reply #61 on: September 21, 2009, 02:37:44 PM »
George is in the car.  Waiting. . .
Offline Kansas Bad Man
    • Max Lambky's Vincent powered motorcycle streamliner
Re: Shootout 2009
« Reply #62 on: September 21, 2009, 02:40:10 PM »
Thanks for the updates SSS.  I'll be getting a check off to you, or better yet, what's your PayPal info?
You best bet there's a few watching to see what the Bub machine will do.  So far nothing has changed from the record Rocky set last year.
                                          Max
Re: Shootout 2009
« Reply #63 on: September 21, 2009, 02:41:25 PM »
Speed Demon is under way.  Tearing the salt says Mike Cook -- I think that's a good thing, though. . .
Through nine, hauling Acura (Dan Warner says).
Entry:
434 MPH!
436 kilo 435 mile
WOW SH*T!
« Last Edit: September 21, 2009, 02:43:39 PM by Seldom Seen Slim »
Re: Shootout 2009
« Reply #64 on: September 21, 2009, 02:44:49 PM »
WOW
Re: Shootout 2009
« Reply #65 on: September 21, 2009, 02:45:22 PM »
Max, on the front page there is place part way down on the left side.
It says Support Landracing.com
Click that and the info regarding Pay Pal is in the middle of the explanation.
Re: Shootout 2009
« Reply #66 on: September 21, 2009, 02:48:19 PM »
What class / catagory is Main running??
Re: Shootout 2009
« Reply #67 on: September 21, 2009, 02:49:09 PM »
Speed Demon in the pit -- George drove in and parked on the tarp just like he was practicing -- not finishing a 435 mph run.  The generator is started, they're wrenching, gotta make the return run complete in about another 52 minutes.
Glen, I'll get a class for you in a while.
Speeds:
Entry:    434.252
Kilo:      436.067
Mile:     435.685
Exit:    435.868
Okay -- if it were running SCTA it's be D/BFS, but all the FIA needs is  299 cu in -- making it in the 3 - 5 liter blown class.  The car is on alky -- FIA doesn't differentiate fuel/gas, doesn't care if it's a 'liner or a roadster.  I don't think aroadster would go 435, though.
« Last Edit: September 21, 2009, 02:58:31 PM by Seldom Seen Slim »
Re: Shootout 2009
« Reply #68 on: September 21, 2009, 03:01:41 PM »
I guess I'd better suggest that you folks out there in internet land -- I'll try to minimise the number of fresh posts -- so use your refresh button -- I often modify an existing post (like I've done three times already on the post with the Speed Demon photos).
Poteet and Main putting spark plugs in the motor now -- getting ready for the return run.   They've got 15 minutes of work left to do -- have 38 minutes yet to finish the run.
You shoulda seen the ring-tailed chute lines -- spun about a zillion times.  All straightened out -- although they lost the pilot chute.  It's been retrieved and returned to the car -- back in and ready for another run.
Re: Shootout 2009
« Reply #69 on: September 21, 2009, 03:02:27 PM »
I'm at the West  Wendover Welcome center.  30 minute access only  Bought a buncha insect killer/flypaper.
Here's a crude map of the course.  The red is the "extension" that's being used, the green areas are the pit locations...more or less.
Looking thru the pit area toward the freeway end, mile 0.  Snowmobile team (Lamtrac) on the left, OSU on the right.
Looking downcourse toward Floating Mountain.
That's it.  Btw, I don't have the time to respond to PMs.  All info will be posted in this thread.
Re: Shootout 2009
« Reply #70 on: September 21, 2009, 03:18:48 PM »
20 minutes remaining on theSpeed Demon return run effort.  They're wrenching in the pits -- know how much time remains.
Okay -- they're having some minor issues -- spark plug wire is pinched, head gasket issue -- won't crank start, so they're going to push start the car.
Main is in the push truck behind the car in the pit -- starting to move it ahead.  This oughta be fun!
« Last Edit: September 21, 2009, 03:23:44 PM by Seldom Seen Slim »
Offline John Noonan
Re: Shootout 2009
« Reply #71 on: September 21, 2009, 03:23:13 PM »
Freud, John Noonan, Johnrex, Seldom Seen Slim, OhioFatboy, BrentMalone, Elmo Rodge, doug odom, vintageracer, thundersalt, Stan Back, Dynoroom, McRat, Glen, Texican, Tom Slick, Larry C, DSR Bruts, 4-barrel Mike, Kansas Bad Man, turborick, spongebob, TINY, Rchop, Boomer, bak189, WZ JUNK, mkilger and 26 fiats are viewing this topic.
Re: Shootout 2009
« Reply #72 on: September 21, 2009, 03:24:27 PM »
That's kicking some butt Old BNI record is 358 mph Hoffman Markley set in 1992 and Al Teagues FIA of 405 mph in 2002 All with single engines blown on fuel.
Re: Shootout 2009
« Reply #73 on: September 21, 2009, 03:27:35 PM »
Car is turned around.  Crew is at the car.
Main is behind in the push truck again.
Moving out!
Re: Shootout 2009
« Reply #74 on: September 21, 2009, 03:29:12 PM »
Car wouldn't fire.  Duttweiler has canpoy open and is talking with Poteet.
