Midget, Marcello:
You’re so close--only need about 10% more.
Some ideas in addition to what has been suggested above.
Aero
Since closing the grill and/or radiator seem to be against the rules, fit a radiator with exceedingly close fin spacing or maybe some damaged fins. Close off any other internal flow paths from behind the grille except maybe a “cold” air duct inlet for the engine airbox. Some of this has been done. More attention will be devoted here.
Lower the car, maybe a bit of rake, too. This has already been done, the max that was easily achieved. More needs to be done. MAY require shorter front tires to improve the rake . . . . . Talking about lowering the front to the point where it's on the ground at launch, because of the high speed lift.
Tire pressures? Probably should have been running the higher pressures all along . . . . . Well, you learn as you go . . . . . .
Were the windows rolled up? Yes. Probably going to check if there is any lexan window deformation at speed.
Power
In the dyno session I seem to recall that you just chose the better of the inlet and exhaust configurations that were at hand. Both of these may respond to refinement and tuning for the generally hotter conditions at Bonneville. Undoubtedly true. Have to get more experience with jetting the carb for the severe Density Altitude differences @ B'ville. What are the inlet and exhaust tract geometries at present? It's a non-standard combination for the engine's displacement, based on what is currently accepted as gospel for BMC's. None of which I care about. We made tuning choices based on dyno results . . . . . Do they work together? Yes and no, er, it's complicated. I picked the inlet length for one peak torque rpm and the header primary length for another, slightly lower peak torque rpm. I did this to flatten the torque curve and give a wider usable bhp curve. Now that Midget has gotten a year with a bunch of good runs, and the car and concept have proven competitive, probably going to do a couple of things to raise the bhp output and narrow the useable power range. One will be to tune the inlet and exhaust tracts to the rpm at top speed. Probably narrow the working range from 2200/2000 rpm to 1700/1500 rpm. With the close ratio gearbox he has, and the narrowed powerband, probably looking at a push start . . . . . .
Icewater intercooler? Definitely, on both fuel and inlet air, if legal in GT.
Front end toe minimized. At factory minimum now, probably going to try less.
Slow down the water pump. It’s probably cavitating at 8k anyway. Already done. His original setup, (and what most Spridget racers use), spun the water pump at 13,000+ rpm at 8000 crank rpm. As I'm sure you will agree, that's crazy. Back in the build diary are photos of the gilmer belt setup I designed and machined to fit this application. It uses a 3/8 pitch toothed belt with a 15/28 under drive ratio for a .5375 w/pump to crankshaft speed. At 8000 crank rpm, 4286 water pump rpm. I wanted to get it a bit lower, but 32.96% of the original water pump rpm is way better. It also uses a wider than needed water pump pulley, so that an additional accessory drive can be fitted. Say, uhmm, a dry sump oil pump . . . . . . .
Interested Observer,
All great ideas, some/most of which have been partially used.
Going to come up with a strategy for reducing potential brake drag. Also going to reduce trans/diff losses by going to lighter synthetic lubricants coupled with lowered fluid levels.
I am confident that the Grenade's output can be raised to about 103/105 bhp reliably. Since the 1310cc F/Prod SCCA engines are making 106/114 bhp/litre (depending on whose dyno numbers you believe . . .) we might be able to achieve that level. Since the 999cc has better breathing capability coupled with lower flow demand, we might even do slightly better. I want to remain realistic though, no Nascar or F/1 budget here . . . . .
As always, thanks for your thoughts.
Back to Fordboy
Midget/Fordboy, a few thoughts--
Ground clearance - I’m not sure if FB was serious about the zero-clearance statement, but it would be wise to maintain at least 1/2-3/4” clearance. You’re not always on a groomed course, and even that can have holes, ruts, ridges, etc. It can also make trailer loading/unloading a challenge or, at least, a more ticklish operation. Do you use alternate, larger diameter “transport” tires and wheels? To avoid excessive aero pitch-up, just strap the front suspension.
Brakes - I’m with you--keep them until they are demonstrated to be a significant issue. Check it out before the discs rust up.
Tow bars - generally result in a lot of salt being thrown onto the racer. A decent length tow strap is pretty simple and effective.
Air/fuel - It is sometimes good to remember that these things are based on an oxygen sensor, and that they simply infer the mixture rate from the remaining oxygen. Also, as I recall, they need to be pre-heated (electrically) to work properly, especially with leaded gas. They can also cease to work well, or at all. This may be at the root of your wildly varying readings. Rather than a gauge, consider a data logging system to gather this info (as well as other useful information, revs, oil pressure, etc.) since there is nothing you are going to do about it during the run anyway. With your wheelbase, you need to be looking down the road, not trying to read and remember gauge readings.
Body seams - While taping up the gaps is an easy thing to do to clean up the surface, that can’t be done, and at 120 mph one might question the effectiveness anyway. Reworking the bodywork to neaten up the still existing gaps seems like a lot of work and expense for debatable benefit unless you have some really grievous misfits, or you just want to do it for aesthetic reasons. See if you can get “Blue” to render an opinion.
Density altitude - Since aero drag is proportional to the air density, and presumably the power output is also proportional, academically, performance shouldn’t vary with DA. I would suspect that the increased temperature may be producing better vaporization and/or a more advantageous inlet and exhaust “tuning” condition.
2V battery - are you saying that the 12V battery dips below 2V? If not, and 2V is sufficient to avoid the problem, what is the problem? A second (motorcycle?) battery would seem a lot simpler for data and instrumentation stability.
Just talking about launching from the deck. I like your idea of 1/2" to 3/4" of front ground clearance, coupled with limiter "straps/cables/chains" better. Trailer loading/unloading is already a "pita", just as it is. Probably going to have to go the "transport" wheel & tire route . . . .
I'm also with you on keeping the brakes, but definitely want to eliminate any "drag", with a system of some sort to push the pads/pistons back a smidge. Currently thinking about Tony's (Maguromic) simple s/s spring setup.
Tow strap, tow bar, whatever gets the job done. But, I wasn't there to brush the salt off, either. Salt with my frozen Margarita? Why yes, thank you!! Salt with my suds? Ahh, not so much . . . . .
I favor data logging, but I'm not the one popping for it. IMHO, drivers have too much to do at speed, and my pro racing experience is that they can't provide enough
accurate data for analysis and preserve their behinds. I'm a disciple of Norbert Singer, I want to keep the driver's job humanly possible.
Unsure at this point what is going on with A/F ratio. Good sensors and data logging would help to solve that problem, but, from experience, I am reluctant to tune for A/F, based on only an oxygen sensor. I would like to collect some of the other data you have suggested, (as well as a couple of other things), and the data logging is the best way to accomplish this.
Some of the body fit could use a bit of help. After all, it's a Brit kit car.
I agree with you on the density altitude and thought the car would be faster in the cool of the morning. However, it's undeniably faster in the heat of the afternoon, (approx. 3 mph!) so we are missing something important here. Could be any one of a number of things.
I favor a second small 12V battery as well. I am devoted to the KISS principle . . . . . . besides, it's an LSR car, not the Space Shuttle. I think the suggestion to add a 2V
battery in series to the existing system, is to keep B+ voltage for the ignition from falling below 12.0 volts. Some electronic ignitions don't work reliably below 12.0 volts, as I am sure you are aware.
Thanks for your thoughts.
