Chris, I just went back and found these numbers. IMHO, the answer lies here. Do what you can to get the aero a little better, to make it easier to pull the RPM's, but for what you need (3mph), i wouldn't get to exotic with it, as you are very limited.
Find those other 400 RPM's!!!!!
Buddy, I did get your texts - sorry, my phone is old school and difficult to return messages on. I should have just called.
Dzus fasteners are in the works to replace the hood pins, but there was never a factory chin spoiler for this thing.
I'm thinking I'll have Bob and Jeff at Midwest Fabrication do some panel alignment and get the body right.
http://www.midwest-fabrication.com/#!home/mainPageThe gaps on this thing aren't what they should be, and I've had a tough time getting them right since the cage went in. Bob and Jeff have seen a
LOT of goofed up stuff over the years - I'm confident they can handle it.
Aero is the issue, but more power would be helpful.
There is a slight hole in the power band @ ~ 7600 . . .
. . . right where it stopped pulling in 4th.
I received an e-mail from David Vizard yesterday. His past work with a similar A-series combination produced 105 bhp, and the best he had heard of was 109 - he didn't indicate where it was in the rev range, but this confirms Fordboy's thought that there's more to be had out of this donk.
But regarding the engine, all plans are on hold until after World Finals. I want to be certain that the existing target is the one I'm aiming at.
I still say electric pumps, plus fuel injection, are the way to go. Both for the water and the oil. These two pump changes should be worth a minimum of 5 ponys.
1. You need every pony that you can get.
2. The pumps are not that expensive (say $150 each) and can be mounted practically anywhere.
3. The weight of an extra battery may actually help traction and won't hurt top speed. I used an old fashion car battery to run mine for a whole day of road racing, without an alternator.
I don't know what the oil flow rate is for an A motor, but I do know:
1. a big block Chevy Hi Volume pump flows 21 GPM max.
2. a '71 VW oil pump flows < 5 GPM @ 6,000 rpm.
I won't speculate as to how many hp are being gobbled up by oil and water circulation, but I agree - if we can remove those tasks from the engine itself, it would free up power to the wheels.
Cooling certainly isn't an issue - it was all I could do to get it above 180, and that's with a very slow turning pump drive set-up.
As to oil circulation, increasing the
volume of oil rather than the pressure would be a huge plus.
EFI would be a help as well. My experience with it is somewhat limited to a Holley ProJection set-up I did on my '65 Ford F100 about 20 years ago. The results were impressive, though - instant throttle response, and on a warmed over 390 with an RV grind cam, Edelbrock manifold, cheap headers, a three speed and a 3:50 gear set, fuel economy jumped from 9 to 14.
