Nitrous is NOT Gasoline. Therefore it IS Fuel. I don?t care about the science involved.
Enough is enough.
Perhaps this would be a good time to suggest that a new class structure be developed for rear engine, classic, hybrid powered, bio-diesel fueled five door hatchback, Korean built, compression ignition, three-wheeled vehicles originally designed to carry at least 5 and 3/8th normal sized adults at high speeds in an artic environment? At least 678.034 such cars must have been available for sale to the general public in New Zealand. There should be separate divisions for bio diesel unblown (CRBDU), bio diesel with nitrous unblown (CRBDUN), bio diesel with supercharger (CRBDS) and bio diesel with supercharger and nitrous(CRBDSN). El Caminos and Rancheros would be allowed in this class as well if at least one front fender from a Korean three-wheeler is attached in the original location. No one piece front ends. To distinguish this class from Production vehicles at least 4 of the following three modifications must be made. 1) Glovebox welded shut, 2) right window rolled down, 3) Left turn signal blinking. Driver must sit totally on top of the engine unless engines were originally mounted on the roof. Cars with XM Radios move up two engine classes. Interiors may be gutted as long as all original upholstery, trim and seats are retained in original position. Lights must be retained but can be painted green. All vehicles (except AA engined Supercharged with Nitrous ? AA/CRBDSN) must be licensed, insured and inspected in Nova Scotia. Flathead two cylinder engines produced in August of 1937 are allowed to run in V2/CRBDU with original heads, (El Mirage only - class minimum 70.0030 mph). Front air dams are permitted if painted orange. (also see vague reference to streamlining in rules for open class motorcycles which does not apply but may be a sticking point in impound never the less). It is suggested that new vehicles entering these classes send seven color photos of the good looking girl next door to the SCTA tech committee (three wheel sub committee) at least 51.6 months before the meet. Traction control permitted, maybe. All vehicles limited to two wheel drive only. Six vehicles with three wheel drive have been grandfathered to run in these classes until 2008. Drivers must have at least three teeth. Waiver for West Viginia drivers will be considered on a tooth by tooth basis. . . .
Anyway . . . Making another set of classes for Nitrous makes as much sense as the bio diesel classes I joke about and suggest above.
But then again .
