I'm wondering how much hp a turbine could extract from say a 500 hp motor's exhaust and then transmit to the drivetrain of said car?
I know that there is enough power generated by the turbine side of a turbo to power the compressor on a turbo. The real gain there is the increase air/fuel charge now going into the motor under boost from the compressor side of the turbo. That air/fuel increase can produce way more hp than the power the turbine side of the turbo is making to power the compressor.
A turbo motor gives up some hp due to the restriction on the exhaust side, but there again that is more than offset with the increased fuel/air now entering the motor.
So my gut feeling is that if you have a turbine in the exhaust powered only by the exhaust gasses, no added fuel, I can't imagine it adding much more power to drive the car after transmission losses, and restrictive exhaust losses.
So back to my original question, how much more usable hp to drive the car would this setup produce?
c ya, Sum
<small>[ March 24, 2005, 06:43 PM: Message edited by: Sumner ]</small>
