I suppose it wont be, but when I read the SCTA rule book I see that the G/GC record is 155.599 mph. Well, a stock Honda s2000 will go close to 160 mph. So if someone where to take a s2000; put in the safety equipment necessary; put on a hard top for the aerodynamics & clean up the rest of it as best you could; change the rear end to a quick change so it would qualify for the class; put on a set of headers & a high performance throttle body & remap the computer to take advantage of it: do the the other few things you would need to get the job done; would you not then have a car that would easily go over the old record? And by quite a bit I would think.
I would think the budget, including the purchase of the car, could be kept to about $25,000 if you did lots of the work and where careful with the purchasing.
And you could drive the car to Utah to boot.
Are these the silly ramblings by someone who is a non racer?
I see that the record for this class is 20 years old. Even the G/GT record is below 160 mph, and is also 20 years old.
I would like to see this thread get back on topic or risk being locked.
I agree. So here it is. I sent an email to the rules committee for clarification and what I got back is that a Honda S2000 CANNOT be considered for /GC as it does not meet the specifications of a Gas Coupe. This is because Gas Couple must be a four seater car (as built by the manufacturor) and the S2000 only seats two. So, it can only be used in /GT (of the two options I presented, anyway)
The other clarification I wanted was, can a Hardtop be used if it is an option on the car from the factory? I have not heard a reply on that yet.
Ok, so here is a further question. Engine swaps are allowed in GT as long as it is the same manufacturer. So if I can find a Honda F1 engine, can I use it? After all, it does say Honda on it. I imagine finding one is the stickler.
Your car is a roadster. If Honda makes a hardtop version of the S2000 that would be a coupe. Hardtop four seaters are sedans, whether two door or four door.
This is what happens when rulesmakers, probably due to internal politics, start using a double secret form of English that no one else speaks.
A hardtop two seater is a coupe. A four seater is a sedan.
http://www.merriam-webster.com/dictionary/coupeMain Entry: cou·pé
Variant(s): or coupe \kü-ˈpā, 2 often ˈküp\
Function: noun
Etymology: French coupé, from past participle of couper to cut, strike
Date: 1825
1: a four-wheeled closed horse-drawn carriage for two persons inside with an outside seat for the driver in front
2usually coupe : a 2-door automobile often seating only two persons; also : one with a tight-spaced rear seat — compare sedan
http://dictionary.die.net/coupecoupe
n : a car with two doors and front seats and a luggage
compartment
Source: Webster's Revised Unabridged Dictionary (1913)
http://www.yourdictionary.com/coup-ecoupé Definition coupé (ko̵̅o̅ pā′)
noun
a closed carriage seating two passengers, with a seat outside for the driver
in British railway cars, a half-compartment at the end, with seats on only one side
http://www.allwords.com/word-coupe.htmlcoupe
noun
an ice cream dessert; the glass it is served in
A car with two doors (variant of coupé)
http://www.merriam-webster.com/dictionary/sedanMain Entry: se·dan
Pronunciation: \si-ˈdan\
Function: noun
Etymology: origin unknown
Date: 1635
1: a portable often covered chair that is designed to carry one person and that is borne on poles by two people
2 a: a 2- or 4-door automobile seating four or more persons and usually having a permanent top — compare coupe b: a motorboat having one passenger compartment
