So the main thing I see there is that it is suppose to be "shatter resistant".............how resistant, who knows. Is Plexiglass shatter resistant at all??
Plexiglas (acrylic) is shatter "resistant" when new, but can easily become brittle with UV exposure, temperature cycles, and age. Lexan can take a much bigger hit from heavier and sharper objects for a given thickness. It is also more resistant to aging effects. Lexan is less forgiving in the forming process, often resulting in waves in the finished product that render it useless.
Stretched acrylic and stretched Lexan are even better. If the material is stretched a specific amount at a carefully controlled temperature along the stress axis (fore and aft for canopies) then the resulting canopy will be 20 to 100% stronger with respect to impact. The military uses this. For really trick armor-piercing-bullet-resistant viewports on weapons pods, they use sapphire.
