Sam,
Filling the 4 miles of ditches nearest to the track mentioned in the environmental assessment would not be as beneficial as you may think. There are approximately 12 additional miles of ditches just outside of the ACEC that Intrepid is using for collection (approx. measured using google maps). Also, the mass balance is at best replacing what is coming off the north side of the highway. 1 coming off then 1 going back on does not result in any additional salt on the BSF. None of this is really reclamation. At best it is just maintaining and limping it along. STS's comments look more to strike the wording of the report that make it seem like there would actually be reclamation happening. It's actually a good catch on their part. Their stance remains the same and that action actually should help now because the BLM, etc. can't look back at the EA and say "see, it should be working just give it time". The only reclamation mentioned in the EA is filling the ditches which just fills ditches they no longer use. They should do that anyway but it will not result in additional salt being on the track, just filled ditches.
Also, in a previous post you brought up the 2023 date for redoing their contract. That is their normal cycle. I think the goal right now is to provide enough outcry and evidence to force the contract back open so it can be revised with some actual reclamation to hopefully rebuild the salt that has been lost. That is why it is such a big political and procedural problem that STS is and the Utah Coalition, etc. is trying to work through right now. There can be all the ideas in the world to try and save it but until something is worked in to the contract everything is going to be on a voluntary basis on the part of Intrepid, they are operating within the limits of their contract and have no obligations to do anything beyond what is in the contract. Hence, the reason to contact representatives.
Gabe
Edit: also, has anyone noticed that their mass balance equation doesn't make sense?
(Y1SL+Y2SL+Y3SL)/(Y1SB+Y2SB+Y3SB)= 0 or 1.0 or greater
Why the 0? it doesn't make any sense and leaves a huge loophole that if they wanted to save money they could just say "oh look, (0ton laydown)/(50ton collection)= 0, I don't have to pump anything back out...profit!".
Another thing, the 2018 study. The requirement just says they have to repeat the 2003 salt crust thickness and if it shows a decrease then the BLM may revise the contract. HUGE RED FLAG for me! It's only relative to the 2003 study, no other studies from the past. As you can see from Russ's measurements over the last 10 years the thickness doesn't just get thinner everywhere, it's dynamic and moves with the water/wind flows, weather, etc. With that in mind, almost any variation between the 2003 and 2018 studies could be well within the margin of error especially with the current laydown project being conducted. Which, leaves another easy out of changing the contract.
