wait a minute.
What am I missing here mathamatically? to get a record - you have to exceed the old record - correct? So every record set must be faster than the previous record - correct. Now Mr. Ratliff in your infiniter wisdom - somehow you forgot the basic principle of statistics - as correctly pointed out by roadsters.com - as apples to apples!
You must standardize the data before you could compare - so the only valid mathmatical comparison was to compare each class - the record in 1971 with the current record in each class. Seeing as how I do not believe that any new record is slower than a previous record, then your entire premise is bogus and may I humbly add - idiotic.
So the correct comparison would be how many new records as compared to how many stayed the same! because records don't go down in speed - unless somehow in Bizzarro ratliff world you wave a magic wand and make em go away!
So as much as you would like to make your claim - it has no validity - either mathmatically - or to anyone with any sort of grasp on reality!
Franklin - you have been caught trying to manipulate data in a way to try and prove your point - while this may make you an excellent politician - it immediately excludes you as a scientist or mathmatian.
You can't seriously think you have a valid point right? you do understand the concept of "record" correct? so can I chalk this one up to ratliff is into the liquor cabinet again !
Carl Johansson
There was no "manipulation." You can't manipulate data when it's a straight adding up of all the speeds and dividing by the number of cars. Mathematicians call that averaging, not manipulation.
The common denominator is IT'S STILL PISTON ENGINES. I wasn't comparing piston engine cars to jets or rockets. You have all the same data. You can do the same adding and dividing I did. It's still not going to give the number you want.
It's still STREAMLINERS, LAKESTERS, ROADSTERS, COUPES, and SEDANS.
Piston engines make more horsepower than they did 35 years ago. So how has it happened that 35 years of technical progress has had no influence whatsoever on the average speed of SCTA car records? After 35 years of progress, shouldn't the average have, you know, GONE UP?
