Am I wrong? I thought you could run Propane in gas classes. And diesel in gas classes. And I have heard that propane and diesel runs very well togeather. Do the diesel guys use propane?
You can use a LITTLE propane or water/methanol injection for hotrodding diesels. There is a fine line between OK, and KAPOW. Generally, at about 100HP gain, things go bad rapidly. It's not a good power adder for diesels, but helps fuel economy. Nobody who is winning is using either one. Too risky for the small gain.
Now nitrous is whole nuther animal. You can spray the snot out of a diesel without problems. 500rwhp or more at a touch of a button. Diesels run "dry nitrous". You don't add fuel externally, nor in the programming. You might want to retard the main injection a little, like 4 deg, but that's only to surpress "bursting". Bursting is normally harmless. When you spray too much nitrous in, it chills the air charge down too much, so the diesel fuel will not ignite when injected, and the engine just dies, like you hit a kill switch.
