Rick would still have #2 available for those who wish to run it. Performance diesel would be available for those who want to step it up. This way we can also dyno and calibrate to a known performance fuel rather than just rolling the dice when we get there. It would be nice to have SCTA on board with this as there are several of us out there that are limited in performance by the speed at which we can burn the #2. Will be much cheaper in the long run to not be burning engines down even if it is 10 bucks a gallon. We don't use nearly as much per run as the spark plug guys.
Trent, This is the spec sheet for Shell racing diesel. I would would assume that ERC would be very similar, and knowing Rick it will exceed it. Tony
