If you were a snake oil salesman you would want to go after a soft record too. Nothing like a world record to make your imaginary engine seem like something you should invest in.
But wait! There's more!
Check out how this thing works.
http://www.cyclonepower.com/works.html"Patented centrifugal combustion chamber" heats the water to 1200º F in 5 seconds! Where does the air come from to support this combustion? I'm pretty sure if I put my teapot in the shuttle's exhaust I might get 1200º F in 5 seconds. They are trying to downplay the excessive amount of time it must take to produce usable steam pressures.
"Steam enters the six radial-configured cylinders under pressures up to 3200 psi to push the pistons down in sequence. Note, no motor oil is used – water is both the working fluid and engine lubricant." The Bulls**t alarm went up to max scale upon reading this. Anybody here try water as a lubricant? 3200 psi? That better be one hell-for-stout motor. That's over 40,000 pounds of force on a 4" piston.
"The rotating action of the pistons connected through a patent-pending spider bearing (not pictured) turns the crank shaft." I love vaporware. Ohhhhh! Spider bearing!!!!
"Note, because the greatest amount of torque occurs at the first rotation, the shaft can be directly connected to a drive train without a transmission."
It doesn't need a catalytic converter or muffler.
"Tetra Ether Lead" "encapsulated in the earth for milliana" Among other misspelled words.
Ain't this baby the greatest! I'm going to dash right out and buy some stock in this marvelous company!!!!!!!!
