Hi Scott, good to see you back here.
you be right - when the tire works!
Interested on this point is the aerodynamic.
if your aero is right, your handling will work and than the tires can reach a much higher speed.
or otherwise - if your aerodynamic didn't work - the aero effect the handling - when you have hard to work on
the handling you stress the tires.....
so - better the aerodynamic is - you are getting a higher speed range from the tire....simple rule......
Due to Joe after the run in September - the faster he went so easier the bike stand solid - no issue with the handling anymore.....hope he can fix the engine for another go this year.
