Author Topic: roll cage question  (Read 3116 times)
Offline brock Hollywood
roll cage question
« on: March 02, 2010, 03:42:14 PM »
I am in the process of building a 91 honda civic to run in the /GALT class. will roll cage tubing that is mild steel ERW pass tech as long as the wall thickness is ok?
« Last Edit: March 02, 2010, 03:43:57 PM by brock Hollywood »
Offline doug odom
    • popmotorsports.com
Re: roll cage question
« Reply #1 on: March 02, 2010, 03:50:36 PM »
Yes, and mild steel is preferred.
Doug Odom in big ditch
« Reply #2 on: March 02, 2010, 03:52:32 PM »
any opinions on the Jegster cages? good or bad?     www.jegs.com :?
Offline 1212FBGS
    • http://www.motobody.com
« Reply #3 on: March 02, 2010, 04:35:36 PM »
Jegs and Summit are going to the dark side.... both are selling Chinese knock off crap.... they even sell a Chinese Holly carb knock off..... spend your money with a good American company like Speedway.... they probably have a cage kit you could make work...
Kent
Offline mkilger
« Reply #4 on: March 02, 2010, 04:44:23 PM »
call Autopower, I sure they make one to fit your car, Ricks # in the rule book.
Offline krusty
« Reply #5 on: March 02, 2010, 05:17:23 PM »
Kent, Speedway led the parade to the dark side; they have purchased the rights to numerous US conceived and manufactured products and have sent the manufacturing offshore. Your statement implies that neither Jegs nor Summit is a "good American company", which is not true. All three are US corporations with similar business models, although with emphasis in slightly different areas.
As far as building a cage, I'd seek out a local late model or drag chassis shop and see if they could bend your tubes. I'd also use 1020 DOM tube, but ERW is legal for SCTA construction.        vic
Offline basher13
« Reply #6 on: March 02, 2010, 11:51:31 PM »
Art Morrison hear in Washington can get you what you need, built in house or cut and bent and shipped to yer door. Great group of people to deal with, :cheers:
118.780mph in a stock(ish) Studebaker
Offline willieworld
« Reply #7 on: March 03, 2010, 12:34:00 AM »
http://www.cachassisworks.com/ftp://                                  willie buchta
willie-dpombatmir-buchta
Offline wolcottjl
« Reply #8 on: March 03, 2010, 07:18:43 AM »
Make sure you have a rule book.  A while ago when I looked the plates that came with most of the pre-built cages did not have thick enough plates for a unibody.  You need to make sure they can provide the right thickness or order the material/plates separately.
Joel Wolcott
Moving to 2 wheels in 2010
« Reply #9 on: March 03, 2010, 10:34:43 AM »
thanks for the great input. I did realize the plate thickness would have to change. Basher, Art Morrison is about a hour away from home for me, I might check him out. I have dealt with them in the past and they do great work. thanks again
Offline 57 ranchwagon
« Reply #10 on: March 03, 2010, 05:09:51 PM »
I used a Art Morrison Kit for my car very impressed with the fit nice and tight to the pillars and roof. I have added some bars and the plates are 1/8 so you need to replace them with 1/4 for SCTA/ECTA all in all very happy with the kit.(great bunch to deal with didn't have my car in the catalog so they sent me a measurement template and it worked out great)
Offline Geo
« Reply #11 on: March 03, 2010, 07:53:44 PM »
There is a thread every one working on a roll cage should read.  Covers thickness and types of tube, strength, welding, intersections, etc.
http://www.landracing.com/forum/index.php/topic,4846.msg67317.html#msg67317
Thanks for everyone's input on the material tubing thickness!
Geo
Offline Kiwi Paul
« Reply #12 on: March 04, 2010, 01:34:24 AM »
Thanks for the link, Geo. Much good info there. Will be a great help when I eventually do the Camaro, also for the Secret Project ,if it ever comes to fruition...
Offline thundersalt
« Reply #13 on: March 04, 2010, 01:19:01 PM »
Plus sandwich plates of the same thickness (1/4")
916 REMR
El Mirage 200 MPH Club
