Terry. I'm a bit confused. Why would you have sent me a picture of an aluminum wheel? I think I have a pretty good idea of what an aluminum wheel looks like. Anyway, I doubt if your design would be anything like my design. My design will employ two halves. The diameter will be 14" as that's what my lathe will swing with the gap out. Each half will have a bevel in the outer edge, and when sandwiched together, will accept a high grade poly V belt, 3/4" wide at the apex. So, when viewing the wheel, there will be a 3/4" flat rubber in the center, and the aluminum radiused from the flat 1/2" on either side, with two small grooves. Timpkin bearings will be used. The width of the wheel will be 1 and 3/4", the width of the fender will be 2 and 3/4". The fender will be adjustable like a rudder on the tail of an airplane.
Max
