The padding you have is a closed cell foam product that is manufactured and sold for applications like you have it.
The SFI stuff is a denser foam that does not have the same bounce back characteristics, and actually can be much thinner, and still offer the same protection.
All you are really doing with it is spreading the load across a wider area to reduce the point load on the helmet.
The best comparison is a constant wound spring vs a progressive wound design.
For the limited travel you have and with it the little bit of bounce around you will ever have in an upset, it is probably just fine.
When you compare it to the protection that any of the other injury sensitive parts of your bod have like the seat against the back bone, it looks pretty good.
Many people took cheap deal insulation foam, then wrapped it tight with tape, and called it good, but we know better don't we ?
SFI is a good resource, but is a US standard that is not adopted World wide , just like Snell helmet standards.
It is certainly a good, and first choice product, but not universally required.
If you get a hold of some, compare it to other methods by smacking it with a closed fist, and that will demonstrate the difference.
Don't do it yourself, but get a buddy to try it, and just watch his eyes, that is what they are for after all.
