so what is the procedure for pumping an engine for displacement verification . I run a diesel , no spark plugs , the injectors are pressed into the head , and secured with a hold down clamp ,not threaded . the injectors are aimed at the piston top center at about a 17 degree angle . so stroke could be measured with an injector removed . I can fabricate a hollow piece to fit tightly into the injector bore , and I guess some sort of an attachment to connect a hose to . so who does this , and what can I provide to make it work . thanks
