SW next yr for the liner, this yr I will just be a tourist.
I was originally going to 4WD the tank but then realised I'd better cut right to the chase so I started building the liner.
I'm not sure that 4WD is nessessary unless you have gobbs of power to hook up. I just have memories of giving Al's tires a hair cut down at the 11 & sending him back again.
ps, Two transfer cases is the easy, simple & cheap way. The front T-case in front of the diff with the pinion facing forward so you can run rear end gears for better ratio choices.
On a NP-205, (no chain) between GM, Dodge & Ford units, there are enough shafts to have 32 spline sticking out of every hole. This will allow the use of standard 32 spline Greek Couplers if you wanted to eliminate UJ's.
