You might look at this thread for a start.
It should give you a ball park idea of where you need to be if you have reasonable information about your frontal area, CD (coefficient of drag) and target speed.
http://www.landracing.com/forum/index.php/topic,7775.0.htmlPage two has a simple program I wrote and WOODY@DDLLC converted it to a spread sheet.
http://www.landracing.com/forum/index.php/topic,7775.msg126539.html#msg126539After reviewing dyno HP numbers vs actual speeds run on cars similar to ours it looks like you loose 15 to 18 percent to driveline/friction. Does that sound about right guys?
Yes that is a typical range for assumptions of drive line loss, although I was told by a former engineer at superflow dyno that it is not actually a simple percentage. Each drive line has a characteristic power loss due to things like throwing gear lube around and bearing friction that is relatively independent of power going through the drive train, then a second loss that is mostly power related due to pressure friction between the gear teeth and such that does follow the power to a limit.
Drive line loss can also be impacted by what weight gear lube you are running and tire pressures (actually rolling resistance) and also what temp the gear lube is.
A hot transmission has less fluid friction loss due to the thinner hot gear lube.
There is also some other interesting reading in the "formulas" sub forum.
Larry
