Author Topic: Getting ready for Bonneville(rebuild)  (Read 1930652 times)
Re: Getting ready for Bonneville(rebuild)
« Reply #2640 on: November 24, 2023, 11:57:12 AM »
Inside view of our record run.
https://youtu.be/IMP35Jjg6IY?feature=shared
     Data log shows Troy AT 30-35% TPS for 8 sec in 1st 35% for 9 sec in 2nd and 50=100% in 3rd at 7300rpm
    engine losing power for 3 sec before finish line.
     Throttle position can be seen left of throttle body.
« Last Edit: December 22, 2023, 04:12:08 PM by jl222 »
« Reply #2641 on: December 22, 2023, 05:18:51 PM »
    We checked the gearing for 3rd gear [ no shift to 4th } gear was  because of the 222 mph time it and 7310rpms seemed that the 25% overdrive was not working but that is not possible. we have three Owens plantary drive transmissions with a shiftless 25% overdrive in rear which puts all transmissions in over drive.
ratios are 1.4st  1,25 2nd  and1.25rd overdrive changes all to overdrive giving a 1 to 1 ratio to third trans before shifting into high and 25% lower gear ratio.
 To check if third was 1 to1 and with 2.50 rear end ratio there should be 2.5 turns of the engine to one turn of the tire.
 It checked out :cheers:
 times were from start of tps 1st 8 sec 140mph 2nd 18 sec 207mph 3rd 32 sec 254mph.
 ENgine lossing power at end data log shows 3 sec video shows 2 sec
 250 x 5200 divided by 3600 =366 ft sec so between 732ft or more loss of power
and speed :-(
« Reply #2642 on: December 26, 2023, 04:43:30 PM »
  Times above are total times from start,
  8 sec in 1st  10 sec 1n 2nd and 14 sec in 3rd.
  32 total seconds.
« Reply #2643 on: January 17, 2024, 08:09:30 PM »
  WE discovered water in the oil after sat run. so put new oil for Sunday run. still water in oil after run ''of course'' Pulled pan off back at shop, ran water through engine and spotted leak at bottom of a sleeve So me heating block with torch and ''Troy'' pulling got the sleeves out. NOT EASY. and we just got them back in Monday using 4 $20 high temp grey RTV silicon gasket makers.
 Bearings looked good but new on way along with new 60 thou copper head gaskets.
 I guess I should take the heads apart , lap the valves , check spring pressure ECT, pain in the ass but no big rush until May meet.
« Last Edit: January 17, 2024, 08:14:08 PM by jl222 »
« Reply #2644 on: February 02, 2024, 01:44:47 PM »
  Data logers are a great tool.
 Got to wondering how fast rpms were building before max at 7310 and revs dying off due to air fuel blow off and 3 sec to tps shut off
 data log shows rpm gaining 300 rpm every 1.5 sec.
 3 sec = 600 rpm.
  Hoping for a good run at may meet: cheers:
« Reply #2645 on: February 18, 2024, 05:26:14 PM »
 Pistons are in, new bearings, pan installed, adjusted oil pump pressure down, will find out how much on fire up, head studs in and we had to in large oil hole in new gaskets to rocker shafts due to slight misalignment. Checked a couple of valves and looked OK as engine has not been run very much. Installing next weekend.
 Only thing left to fix is patching header where AF monitor blew out.
« Reply #2646 on: March 01, 2024, 12:49:54 PM »
  Heads on last weekend, Install lifters, pushrods, intake manifold and blower tubes this weekend.
 IF Troy doesn't go desert riding. Lots of rain forecast so maybe not.
« Reply #2647 on: March 03, 2024, 02:18:01 PM »
[/quote
 All the above done except blower tubes.
Valves adjusted and A/F blow out hammered back and ready for welding.
  Once welded, one more day in shop and ready for fire up.
« Reply #2648 on: March 10, 2024, 04:36:55 PM »
  Engine together, Brad Bosworth welded air fuel bung back in header with extra bead around it.
 SO once installed, ready to fire.
« Reply #2649 on: April 12, 2024, 08:34:13 PM »
    Engine together headers on checked fuel pressue with electric primer and leaks at an injector, after changing seal several times figured out mounting bracket was bent out an 1/8 in. causing the leak.
  fired her up ran great but oil pressure to low after warm up.
 Took pump down to System One [about 70 miles] and found out pump was not set up foe high pressure?
  Oh well, should have been. A spring change and another small part and should have much more pressure.
  AND NO CHARGE :cheers:
  Also a small leak in #16 90 degree fitting at oil pan.
 Ordered new fitting, hose and oil from Summitt on Friday and delivered on Monday
                  JL222.
« Reply #2650 on: April 26, 2024, 02:56:08 PM »
   Fired her up last weekend and low oil pressure adjusted pump for more, no change?
   Took oil return line to dry sump tank and into bucket, fired engine, amazing amount of
oil into bucket in few seconds proving plenty of oil to engine and pan for pickup.
 Hoping high pressure damaged gauge, Ordered new 400 psi gauge. Can this happen?
  Will check oil flow to gauge tomorrow and check line again for blockage.
« Reply #2651 on: April 29, 2024, 08:47:00 PM »
  Before installing new 400 psi guage we turned the engine over ignition off to see if any pressure with old guage 5 lbs. New guage 100 lbs cold cranking and cold 70 wt oil.
  Fired up 230 lbs @ 2000 rpm  COLD OIL after warm up and a little adjustment  150 LBS.
   150 lbs hot oil that's what we want to leave the line at El Mirage in May
« Reply #2652 on: May 12, 2024, 11:12:31 PM »
  Always somethim, but in this case a good thang, warming the engine to set valves last week notice water in #6 and 7 headers
   We think because a water shutoff valve was off [ we almost never shut it off]  on 1st startup no water was getting to block and temp gauge was reading low because of no water :oops:
 So heads off, looking at gasket, what's that water mark on gasket from head ?
New gaskets didn't have a water hole between #3 & 5 & 4 & 6
Drilled new holes and used red silicone that we usually use,.
 ALSO found a 4 in ripped silicone sleeve on boost pipe at super charger.
  So in the long run the water leaks turned out good
 Camaro in trailer truck loaded and heading to El Mirage Thursday.
« Reply #2653 on: May 13, 2024, 01:21:40 PM »
John,
Glad a problem turned out to be a plus. It is amazing these damn race cars, you just can't look at them enough!
Good luck at Elmo!!!
