Author Topic: 1000cc Sportbike commonly reached speeds in mile  (Read 5323 times)
Offline r1kurt
« on: February 24, 2013, 04:21:02 PM »
LSR nOOb here, I was wondering what are the speeds commonly reached on stock 1000cc sportbikes in a mile.  For those that dragrace the same bike, I usually trap at 145+ in the quarter with stock gearing. And was curious if anyone could give me an idea of what I could POSSIBLY run in the mile, I have slightly taller than stock gearing and am very light. Bike will not be lowered at all (thats how it is dragraced) Any answers would be very helpful and appreciated,any advice would be great as well. Thanks guys and girls, Kurt J.    (Bike to be used will either be a 2006 or 2012 Yamaha R1)
Offline 55chevr
Re: 1000cc Sportbike commonly reached speeds in mile
« Reply #1 on: February 24, 2013, 06:55:27 PM »
Dean Sabatinelli went 190 mph at the Ohio mile last April on a production BMW S1000RR ....
« Reply #2 on: February 24, 2013, 07:37:39 PM »
Id guess 175-185 at stock height, but its difficult to say, tuck and riding style makes a big difference. Bring it out and see.
Joe, my bike was new zx10, the bmws are faster.
Dean
Offline 55chevr
« Reply #3 on: February 24, 2013, 08:57:43 PM »
Dean - my mistake ... I remember the bike.
Offline r1kurt
« Reply #4 on: February 24, 2013, 10:22:33 PM »
Thanks guys, Dean was the ZX's ecu flashed and stock beyond that ?   If its worth a few mph, I will lower it.  I'd like to be as prepared as possible.
« Reply #5 on: February 25, 2013, 11:53:40 AM »
I would lower your bike a little, but not like dragracing. At speed you will need the travel.
My bike was reflashed and had a little engine work.
Hope to see you in April.
« Reply #6 on: February 25, 2013, 09:18:57 PM »
What is flashing and reflashing an ECU?
Offline RidgeRunner
« Reply #7 on: February 26, 2013, 05:50:12 AM »
     Re programing it to change timing curves, fuel maps, etc.
Offline RansomT
« Reply #8 on: February 26, 2013, 09:53:49 AM »
For the particular bike mentioned above, Kawasaki had to nutter it so it would pass the USA EPA sound level test.   EPA test the bike by taking sound readings at 1/2 RPM of where peak HP occurs.  Kawasaki removed timing above a certain RPM to lower where the peak HP occured.
Offline runt13
« Reply #9 on: February 27, 2013, 08:20:38 PM »
145mph in the 1/4, just times it by 4. 580mph, simple math....that was easy!
who would have guessed it would take so long to go so fast for such a short time?
2012 Wilmington mile
April meet,
p/pp-1350/4 record, 132.601mph
September meet,
p/pp-1350/4 record 139.915mph [bump]
p/pp-1650/4 record 142.364 mph
p/pp-2000/4 record 140.009 mph
p/pp-3000/4 record 144.511 mph
2013 Wilmington mile
July meet,
m/pg-1650/4 record 137.278
m/pg-2000/4 record 136.695
Sept meet,
p/pp-1350/4 record 141.1986 [bump]
2014  Wilmington mile
May meet
p/pp-1340/4 record 142.5855 [bump]
Offline r1kurt
« Reply #10 on: February 28, 2013, 01:08:38 AM »
In the case of my 2012 R1, the fly by wire throttle closes the throttle plates to 84% at 12,000rpm even when throttle is held WFO at 100%. The ZX10 does this as well, not sure of the % though. Reflashing the ecu removes this, I gained 8hp at peak hp rpm after flashing the ecu. Peak hp rpm is now 700-800 rpm higher.
Offline gsx-rboy750
« Reply #11 on: March 29, 2013, 07:34:45 AM »
I can change that! I made a r6 i am working on 1=1, 46=46 100=100TPS wise.
check out NoRegretPerformance on FB.
200mph on a 100% stock 750 motor, pump e85 in the standing mile.
Offline shiphteey
« Reply #12 on: April 27, 2013, 08:39:32 PM »
On a calm day I can see low 180s for you.
Gemini Motorcycles
229.6 mph at Loring
201.957 mph 2-way average @ Bonneville;
203.85 @ the Maxton Mile
207.2 @ Maxton -- NAKED
200.2 mph @ TX Mile
195.6 mph on GPS @ the 9/10ths
9.4 @ 157 in the 1/4
Offline relaxedphit
  • Organ Donor...refrigerate after opening
« Reply #13 on: May 10, 2013, 12:28:17 PM »
Dean, Is the clearance a function of the track at Maxton or suspension compression at speed?
« Reply #14 on: May 10, 2013, 01:38:03 PM »
For sure a need at Maxton (RIP) for the bumps, but ground clearance is handy at any track for the heavy fork compression in shutdown.
