Author Topic: G/F class lakester in Wichita, Kansas  (Read 222457 times)
Offline ggl205
Re: G/F class lakester in Wichita, Kansas
« Reply #300 on: July 11, 2017, 09:56:57 AM »
Time to see if the front wheels fit without interference. Of course, they did not. I like using anti-ackerman on my race cars but due to the small wheel diameter and wider width, the steering arms contacted before wheels could be mounted. So, I now have a little Ackerman in my steering. No big deal.
Offline Mr. Schimstock
« Reply #301 on: July 11, 2017, 01:42:36 PM »
Those rims look really small.  What tires are you running?
Sproing, crack, ouch!
Offline ggl205
« Reply #302 on: July 11, 2017, 04:45:43 PM »
250 mph rated, 18X4.4 aircraft tires.
Offline Speed Limit 1000
« Reply #303 on: July 11, 2017, 08:42:11 PM »
18 X 4.4 is the tire. The wheels are 10 inches :cheers:
Offline ggl205
« Reply #304 on: July 17, 2017, 11:30:59 PM »
Made some real headway today. Firewall just about done. Found some 1000 degree (F) sealing tape that made things easier and fire putty for all other hard to get at areas. The engine cover, nose and forward body section are now in high fill primer. Used a paint roller to apply and was very pleased with results (see images). Thanks for the roller idea, Mike. Aero bubbles turned out well too. For those wondering if I penetrated the inner vertical plane of my wheels/tires with these aero bubbles, I strung the car from front and rear centerlines and am legal with a little room to spare up front. Actually, both bubbles tuck inside the widest part of my body so no worries.
« Reply #305 on: July 18, 2017, 02:12:19 AM »
John, stringing from front to rear is not enough. The parts must be within the narrowest of the two.  :cheers:
Wayno
« Reply #306 on: July 18, 2017, 02:30:27 AM »
Way to go John.
That looks good man.
Glad to be of help. :cheers: :cheers:
Offline ggl205
« Reply #307 on: July 18, 2017, 04:13:27 AM »
Wayno
Wayno:
I measured out from the front centerline of the chassis to the innermost part of my front wheels. I took this front measurement and repeated it from the centerline of the rear part of the chassis. The widest part of the body fits within these measurements and a little to spare. Rear track is far wider than the body so no worries there.
« Last Edit: July 18, 2017, 04:20:54 AM by ggl205 »
Offline ggl205
« Reply #308 on: July 20, 2017, 05:19:15 PM »
Well, the lakester just got 12 pounds heavier. I had to ad a separate scatter shield for the clutch. No way to do one for both flywheel and clutch so...
« Reply #309 on: July 20, 2017, 07:06:42 PM »
You'll have to help me -- that doesn't look like an "enclosure" -- maybe a "deflector".
Offline ggl205
« Reply #310 on: July 20, 2017, 09:56:34 PM »
Stan, I must have missed it but I cannot find anywhere in the rulebook where the flywheel and clutch shield must be an enclosure. Both my clutch and flywheel shields are 360 degrees so maybe that serves as an enclosure? It is impossible to fully enclose my transaxle the way a conventional gearbox can so yes, it does deflect any clutch parts that may try and exit the transaxle bell housing. Deflectors extend well past the clutch and are very close to the trans case so an argument can be made that it is an enclosure. But the real reason for those deflectors is to create room for coil over dampers and still give as much explosion protection as possible. The flywheel, however, is fully enclosed. I bounced the finished product off to SCTA tech and they said OK.
« Last Edit: July 21, 2017, 10:44:10 AM by ggl205 »
« Reply #311 on: July 20, 2017, 11:15:27 PM »
When are you going to mount the tires?
Offline ggl205
« Reply #312 on: July 21, 2017, 12:14:27 AM »
Right after they are shaved. I do have a question about assembling the two piece wheels. Are you in Wichita now?
« Reply #313 on: July 21, 2017, 12:25:43 PM »
No at work in Denver. Lube torque the bolts. Our wheels have the spec molded in. 5/16 bolts with AN flat washers on ours
Offline ggl205
« Reply #314 on: July 22, 2017, 10:30:03 PM »
Both front tires have now been mounted on Mourer made, two piece wheels and leak tested. I just snugged down the 3/8" grade 8 bolts and zero leaks. Once we shave tires and apply Alodine 1201 to all aluminum wheel surfaces, I will remount them and torque those bolts to 42 ft. lbs. with lube. Oh yeah, I used AN flat washers under bolt heads and nuts.
