Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
Home
Help
Search
Calendar
Login
Register
Landracing Forum
Tech Information
Technical Discussion
(Moderator:
Push start bar with ball in it
« previous
next »
Pages: [
1
Go Down
Author
Topic: Push start bar with ball in it (Read 4372 times)
kustombrad
on:
September 29, 2013, 03:08:53 PM »
Anyone know who makes the pushbar for putting on the racecar that has the little ball at the end?
My projects.
http://www.landracing.com/forum/index.php/topic,13660.0.html
http://www.jalopyjournal.com/forum/showthread.php?t=327069&highlight=project+49
SCTA/BNI timer 1983 to 2004, Retired,. Crew on Tur
Re: Push start bar with ball in it
Reply #1 on:
September 29, 2013, 03:56:34 PM »
We made our own, roller balls come in different sizes and mount type, ours is a 1 in ball welded to a tube.
kustombrad
Reply #2 on:
September 29, 2013, 05:00:38 PM »
I'm looking for the roller balls! Who carries them?
My projects.
kustombrad
Reply #3 on:
September 29, 2013, 05:03:20 PM »
I think I just found some in Mcmaster Carr
My projects.
Reply #4 on:
September 29, 2013, 07:07:53 PM »
Google image or Ebay & search conveyor ball. You can get stainless or nylon if you're going to the salt.
Howard
Reply #5 on:
September 29, 2013, 08:43:20 PM »
I built my own on both liners by taking a oiece of heavy wall tubing and champhering the inside on a lathe, welding a piece of 16 ga, tubing to it that stuck out just past the center of the ball and tapping gently with a hammer to curl the thin wall around the ball enough to hold it in. An occasional shot with spray lube keeps it free and I never had any problems with it. I believe I used a 1" steel ball from McMaster-Carr but obviously the tubing must be sized to suit the ball being used. I hope this helps someone.
Howard Nafzger
dw230
Reply #6 on:
September 29, 2013, 08:49:49 PM »
Hi Howard,
Nice talking with you while we waited for the salt not to dry a couple of weeks ago.
Dean Los Angeles
Reply #7 on:
September 29, 2013, 10:53:28 PM »
Roller transfer units are used on conveyors to allow boxes to move in any direction. Basically a big captured ball.
SKF bearings has a complete catalog with bearing load ratings to 4,000 lb.
Howard
Reply #8 on:
September 30, 2013, 08:35:03 PM »
Most of those that I have seen are pretty bulky. Maybe that is not important to many.
Howard
Reply #9 on:
September 30, 2013, 09:03:04 PM »
The Turbinator has two, they are one inch in Dia. side by side, not bulky at all.
Howard
Reply #10 on:
October 06, 2013, 09:39:02 PM »
8-)Nice to see you also Dan. It has been a while. See you again in a few days.
Howard
superleggera
Reply #11 on:
October 07, 2013, 01:50:35 PM »
Various ones out there as mentioned above -- these are what are on the Poteet/Main Speed Demon
alwayse.co.uk part#7154-13 (link -->
http://www.alwayse.co.uk/en/products/hevi-load_ball_transfer_units0123.html
Last Edit: October 07, 2013, 03:43:40 PM by superleggera
- me: Mark - home: Dry Heat, AZ USA - build: motorcycle streamliner
Pages: [
1
Go Up
« previous
next »
Landracing Forum
Tech Information
(Moderator:
