I started before the last two responses but that's what I'm lookin for.....
straight as an arrrow.....and short stroke motors....sound familiar Chris?
yeah
Well Gogg's, It looks like everybody's talking about their stuff & you are probably interested in your stuff.
Short stroke engines like your 3.8 are never going to be a stump puller so you've gotta RPM them & that means more speeds in the trans to keep it on the boil.
You can over cam a low compression engine, you really can't over compression a mild engine assuming you have the octane to support it.
Too much cam & porting on low compression will actually cause an over scavenge situation.
Which is one of the issues I discovered in North Carolina - along with a few other problems. Had I not spent the first 1/4 mile just getting the darned thing up on the cam, I suspect I'd have been in striking distance of the old Maxton record.
I've seen the pictures of your heads - you can drive a truck through those ports. The valves are big with respect to the cylinders - so unless there is some issue with the valve bowl area, flow should not be an issue. But you are leaving horsepower on the table by not jacking up your compression.
I know Jack Dolan suggested the parameters, but at this point of the game, I feel pretty confident that you can maintain the durability you're looking for and that was initally designed into the build, and still wring some more ponies out of the new donk by upping your CR.
The problem is - and I'm quickly becoming aware of this - is that with a small displacement, short stroke engine, it's tough to make up CR without looking at either shaving the heads a LOT, and in my case, to the point of the ragged edge of reliability, popping up the pistons above the deck height, using a domed piston of some sort, or a
compromise combination of all three.
When it comes time to put the REALLY short crank in that I sent you, that is when you'll start enjoying the Technicolor, panoramic nightmare I'm encountering with widened lobe center angles and other such mathematical voodoo. It's not for the faint of heart, so come that day, keep many sharpened pencils handy.
At Gairdner, you have a huge advantage in that you actually have some air to work with. Bonneville is 4200 feet above sea level, you'll have 14% less air density to fill those little cylinders come that glorious day the SOS is shipped over and arrangements are made to tow it to Wendover. It's been said that the lower air density is often a wash because you wind up with less aero drag, but that only works on cars with bad aero.
You've nowhere near maxed out the rev potential of the 3.8, and it's not likely that you will with the new diff gears. Get the CR up, buddy - carefully and thoughtfully build up the torque curve, and the power will follow.
