Take a photo enlargement of the side view as seen by the wind.
Glue it to a piece of poster board and cut it out exactly to the side view.
Pinch it lightly between 2 fingers and hold it up along the top edge.
The point that it balances tells you that the surface area in front and to the rear are close to being the same.
The shape of the body as the air passes over it will make a slight difference but it is close enough for your purpose.
When doing the weight balance, be sure the operator is in place with all the other stuff ready to run also like fluids, and do both sides.
