Because the airflow patterns are so different between open wheel and closed wheel vehicles, this series of posts will deal with open wheel vehicles, specifically the air flow around the tires. Hopefully at a later date we can talk about airflow patterns around the tires on closed wheel vehicles.
A French inventor and engineer Nicolas Cugnot built the first known self-propelled mechanical vehicle in 1769. His creation was steam powered and made use of one of the first known methods to convert reciprocating motion to rotary motion.
Viktor Schauberger from Austria was the first person to recognize vortices in nature.
Frederick Lanchester from Great Britain, made the first full descriptions of lift and drag and made models of vortices that occur behind wings.
Charles Goodyear invented the rubber vulcanization process in 1844.
Robert Thompson invented the pneumatic tire in 1846.
Tires with beaded edges were first used in the United States in 1892.
The Michelin brothers made the first pneumatic automobile tire in 1895.
Wheels for land speed racers have been everything from stock tires and rims to specific built race tires and rims to forged aluminum alloy rims with carbon fiber wound around them.
The thrust driven vehicles will usually have their tires and rims made of billet aluminum with carbon fiber wound around them, most rubber tires would disintegrate at the speeds these vehicles operate at.
Wheels and tires ran in open airflow will have very unstable airflow that moves from side to side as the tire rotates and will have large areas of airflow unsteadiness and separation. The turbulent airflow behind the tire is controlled by counter rotating vortices.
The tire sidewall profile, shape of the contact patch and if the wheel tire combination is running covers over the axle side and the outer side of the rim, will have a large influence on the airflow around the tire. The tire air pressure will influence the airflow around the tire also, as it will affect the shape of the tire and the contact patch. Wheel camber angle will affect the airflow and the vortices around the tire due to changing the tire deformation.
Most compressed air sources will contain moisture that will increase the expansion rate of the compressed air in the tires as they are heated. Dry nitrogen will expand at a lower rate than the moist air and hold the set tire pressure longer than the air. A drop of 25% in tire pressure will reduce the tire life by 15%. Nitrogen makes up 78% of the earth’s atmosphere by volume. Increasing the pressure in the tire will decrease rolling resistance and on hard surfaces will decrease stopping distance. Tires are permeable to air and will lose pressure over time. Severely overheated tires can give off flammable gasses and it can react with the oxygen in the air used to pressurize the tire and cause an explosion to occur, the use of nitrogen to pressurize the tire will stop this from happening.
Tires have a fixed shape and bad aerodynamics. The main function of a tire is to put the power to the ground and not aerodynamic properties. On an open wheel car the tires will typically account for 30% to 60% of the total drag on the vehicle and generate a large amount of unwanted lift also. The amount of lift the tire generates will depend on the size of the tire. The drag of the tire is proportional to the tire frontal area, so reducing the tire size will reduce the amount of lift and drag generated. Tires and wheels on open wheel cars will generate more lift than drag. The tires can also greatly influence the airflow around the rest of the vehicle also, including the underbody and brake cooling as well as wings and upper body surfaces.
The atmospheric air pressure at sea level is 14.7PSI. Water vapor weighs less than dry air. Moist air has a lower density than dry air. Drag and down force will increase as the air density increases. As air temperature increases air viscosity will increase also. As air density increases its viscous effects will increase.
Be sure the tires are spaced far enough away from the body, so the turbulence they produce will not interfere with the airflow along the body. By keeping the tires spaced at an adequate distance from the body, the air will have enough room to smoothly flow between the body and the tires, without the two air layers interfering with each other. If the two air layers were allowed to meet, the total drag generated would be greater than the sum of the two. The air turbulence from the tire, will usually cause the wake to spread out from 14in to 18in on each side, behind the tire, depending on the size of the tire and the speed. Because of interference from the axle-spindle side of the tire, the vortice and ensuing wake generated from the inner side of the tire will be less than the outside.
As the track width of the wheels is set wider it will give better stability but will affect spring rate and dampening. The narrower the track width of the wheels it will firm the suspension and the wider the track width it will soften the suspension.
Having the same track width for the tires, front and back, will aid in reducing drag. The front tire will break the air and the rear tire will pass through the hole the front tire made more easily, reducing the drag on the rear tire. Like cars drafting or bicyclists following behind each other, the airflow is only disturbed once. In bicycle racing the rider produces 70% to 80% of the drag. A bicycle racer drafting the racer in front of him will exert 30% to 40% less energy.
If it is a grooved tire running on a hard surface, there will be very little airflow passing between the tire grooves and the ground.
At high speeds, aerodynamics will affect the vehicle speed and acceleration rate more than any single factor in a LSR vehicle. The front surface of the tires is pushing against the air. The forward acceleration of the air generates drag. As the tire passes through the air it leaves a void behind the tire that that air moves into from all directions to fill. The air can’t move backwards through the tire and the air can’t move upwards through the ground. This results in forward drag and due to the forward and downward acceleration of the air in front of the tire, lift is generated because of a high pressure area at the base of the leading edge of the tire, just in front of the contact patch at the ground, as the surface of the tire moves toward the ground and the contact patch it moves energy to the stagnation point and increases the pressure as the speed increases. Because of the tire rotation it will cause separation of the airflow at the top of the tire, earlier than would normally be expected. Due to the separation of the airflow at the top of the tire generating a low pressure area and the high pressure area at the base of the tire, lift will be increased more than normal. There will be a negative pressure at the backside of the tire, due to the void. At the rear of the tire, at ground level, the airflow will stagnate at the contact patch near the center of the tire and move to the left and right, splitting to each side of the tire. The airflow in front of the tire, then moves up the tire surface and towards the center of the tire due to the low pressure area located there. The high pressure at the front of the tire and the negative pressure at the rear of the tire will generate a pressure drag due to the differential pressure.
Because the tire is a circular shape, the air will treat the tire as if it were 2 different halves. The air hitting the front of the tire will move down from the center and the top half will move up from the center and over the top of the tire and separate from the tire surface. The air moving down from the center will strike the tire ground contact patch area and build up pressure.
Due to the rotation of the tire, the air flow in front of the tire goes down towards the ground and as a result, the stagnation point will be lowered closer to the ground and will continue to be lowered as the tire rotation speed increases.
Airflow around the tire and through the rim will depend on if the tire and rim combination are running wheel covers on the front and backside of the rim. Using wheel covers on both sides of the wheel, will reduce the drag by up to 25%. The wheel covers will stop the airflow from passing through the wheel from one side to the other and make the aerodynamics better around the tire also.
There will normally be 3 sets of vortices coming off of the tire, trailing in the wake behind the tire, they will be counter rotating.
There will be a very small counter rotating vortice generated from each leading side of the contact patch and wrapping around the bottom of the tire and down each side, at ground level, following the shear layer into the wake behind the tire. The high pressure in front of the tire at the contact patch and the lower pressure at the sides and rear of the tire will cause the air to move laterally to the side of the tire and speed up, this is called “jetting”.
The second set of vortices are the largest and most persistent in the wake behind the tire. They will be generated at the center front of the tire, at the leading edge, where the airflow splits and travels down the front and up across the top. The vortices will wrap around each side of the tire. One vortice from the front center to the axle side and one from the front center to the outer side. Each vortice will be counter rotating, traveling from the center of the tire around the rear sidewall and into the wake behind the tire. The outer vortice will have a clockwise rotation and the inner vortice will have a counter clockwise rotation. The vortice on the outside of the tire will be larger and longer because it is in open airflow. The vortice on the inner side of the tire will be smaller in size and shorter in length because of the axle tube and the spindle affecting the airflow around the inner side of the tire. These 2 vortices will dissipate slowly as they travel downstream in the wake, and will last for a considerable time. The Separation of the airflow at the leading edge of the tire causes an area of reverse airflow on the axle side and the outer side also. The separation will follow the curvature of the tire and will cover about 30% of the axle side and the outer side of the tire and rim surface. The airflow from the leading edge of the tire accelerates as it crosses over the face of the tire and moves toward the sidewall. Because of the airflow acceleration it will bypass the edge of the tire and create an area of reverse airflow with a weak velocity.
The third set of vortices will come off of the top of the tire, travel partially down the back of the tire before separating and traveling off into the wake behind the tire. The airflow forming the vortices off of the top of the tire will separate, because the air is slowing as it crosses the top of the tire and starts down the backside. These vortices will dissipate quickly, as they merge with the other vortices in the lower wake.
On a tire and rim with no wheel covers on either side, running on an open wheel vehicle, air will enter on the wheel axle side because of the closure of the airflow separation and circulate through the holes in the rim and then move downstream on the outside of the rim because of the low pressure area being generated in the wake on the trailing edge of the tire, creating a suction. Some of the air flowing from the outer, center of the rim, will partially go towards the area of reverse flow on the leading edge of the tire, but most of the airflow will go into the low pressure area behind the tire at the trailing edge.
Starting in 1991 air deflectors were used on F1 cars to blow air into the low pressure area behind the front tires, to lower the drag generated by the tires. In F1 the open tires generate 50% of the drag for the entire vehicle. A good example to look at, for the front air deflectors, would be the 1993 McLaren MP4/8 F1 car.
Because of the rotation of the tires, the vortices they generate and the pressure differentials created, the tires can have a large influence on airflow around and underneath the vehicle if they are not kept at a distance from the vehicle body.
The tires generating a wake at their backside, creates a negative pressure, which can pull airflow from under the vehicle. This can lower down force, if the vehicle was set up to generate down force from the underbody.
The tires generate so much drag it would be worthwhile to add some air deflecting devices to channel some airflow into the wake behind them, to reduce the negative pressure and reduce the drag being generated. Some engine exhaust, if rules permit, can be redirected into the wake behind the rear tires to lower the size of their void. The air deflectors will add some drag but at a cost of having a lower overall drag due to the tire drag being decreased.
