Now this is where all of the bad things start to happen, the free stream air flow treats the boundary layer as if it were the actual vehicle surface, so when the boundary layer grows in size as it becomes turbulent and wants to totally separate from the vehicle surface and become even larger, drag increases dramatically and at the same time pressure drag increases behind the vehicle.
Even though turbulent boundary layers cause more drag than laminar boundary layers because of higher skin friction, it moves the point at which the boundary layer would otherwise separate from the vehicle causing lower drag pressure, it is still much better than the boundary layer becoming totally separated from the vehicle surface. The boundary layer if controlled can cause a reduction in drag. The longer the boundary layer can be forced to stick to the vehicle surface and conform to the surface shape before separating, the drag will be lower, even if it is only one inch on each side and one inch at the top you will still have a lower drag than if it were allowed to totally separate.
By re energizing the slowing boundary layer and forcing it to be turbulent for a longer period it can delay the flow separation and even finesse it to become reattached to the vehicle surface, thereby lowering the vehicle drag.
To get the best drag reductions, the size of the riblets will have to be tailored to the boundary layer thickness and the speed of the vehicle and the pattern of the riblets on the vehicle surface will have to be a random pattern , if the riblets are in uniform rows the drag will actually increase dramatically.
What the riblets do are, turbulence is increased on the peak of the rib but laminar flow is maintained in the groove and even though the surface area is increased the shear stress is lowered.
The riblets will lower the thickness of the boundary layer and reduce the surface turbulence. The effectiveness of the riblets to reduce drag can be on the order of 5% to 14% depending on many variables from air density, vehicle speed, shape and to how clean the riblets are, to work properly the grooves need to be very clean. In a turbulent boundary layer riblets can reduce friction drag to a level below what a flat plate is.
In the early 1980’s the initial R&D for the riblets was done at NASA langley research center. When the 3M Company read the research papers they started development of a riblet adhesive film that could be applied over surfaces. The adhesive film was named “Scotchcal MarineDrag Reduction Tape” the first known use of the 3M drag reduction tape was in 1987 in the Americas Cup on the ship piloted by Dennis Connor on the ship “The Stars and Stripes” after winning 4 straight races the rules were changed and the riblet tape was prohibited.
3M does not sell the tape or market it, the price of manufacture was said to be to cost prohibitive so production ceased.
I have used vortex generators, turning vanes, boundary layer suction, surface riblets and .040 air jets blowing at 50psi, all to keep the boundary layer energized and attached to the vehicle surface to reduce drag.
