Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
Home
Help
Search
Calendar
Login
Register
Landracing Forum
Bonneville Salt Flats Discussion
Bonneville General Chat
(Moderator:
Parachute Mounting on a Coupe?
« previous
next »
Pages: [
1
Go Down
Author
Topic: Parachute Mounting on a Coupe? (Read 3531 times)
38flattie
on:
June 05, 2011, 03:55:45 PM »
OK, We're ready to mount the parachute, but not real sure how we should do it. It will be low on the trunk lid. I thought about a receiver/hitch setup, with the receiver coming through the trunk lid.
Can you guys please post pics of how you did it, explain how you did it, etc.?
Thanks in advance!
http://www.flatcadracing.org/
http://youtu.be/89rVb497_4c
jww36
Re: Parachute Mounting on a Coupe?
Reply #1 on:
June 06, 2011, 10:57:11 AM »
38flattie;
There's probably lots of ways to do it, but I incorporated the push bar mount and chute shroud lines mount into one unit as they both want to be centered to the car. The push bar mount uses a trailer reciever hitch set-up as you suggested, with .25 tabs coming off bottom of outer reciever tube with two hole locations for chute shroud line connection.
38flattie
Reply #2 on:
June 06, 2011, 11:50:55 AM »
John,
Thanks for the info- it's very helpful!
Cajun Kid
Rajun Cajun Racing E/CGALT 5690
Venable Rod's & Racing #805 Studebaker, #806 Ford
Reply #3 on:
June 06, 2011, 07:43:01 PM »
Here is my combo parachute mount/push bar,,,, works great
Last Edit: June 06, 2011, 07:44:58 PM by Cajun Kid
ECTA Record Holder Maxton
OHIO
B/CGALT, C/CGALT
A/CBFALT, B/CBFALT, C/CBFALT, C/CFALT, C/CGALT, E/CGALT, E/CFALT
Fastest Standing Mile at Ohio 203.343mph
Blog
www.venablerodsandracing.com
email venableracing@gmail.com
jimmy six
Reply #4 on:
June 06, 2011, 09:44:54 PM »
Make sure you use a large enough bolt and I would reccommend at least a 1" diameter at minimum bushing the chute line will need to go around. I looks like Cajun's is nylon which is good choice. Make it easy to remove. At Bonneville we wash our chute after every run. Dip it in 5 Gallon buckets of water and hang from the cover shade while we service the car. They always seem to be dry when we are ready to pack.
I don't know what size chute you have for your car but the bigger they are the harder they hit. You may be adding vents or choking it down if it is a tri-form style. Hope you run 175 so you can "need" it.........................Good Luck
Cajun Kid
Reply #5 on:
June 06, 2011, 10:24:26 PM »
Jimmy Six, I agree with at least a 1" bushing,, I used a 1 1/4" solid aluminum rod then drilled a 1/2' hole and used a 1/2" grade 8 bolt,,, It works great.
Also a soft hitting Stroud LSR Chute.
Charles
OHIO
B/CGALT, C/CGALT
Blog
38flattie
Reply #6 on:
June 07, 2011, 09:37:15 AM »
Thanks for the info and pics, guys! This gives me somewhere to start.
As for 175, I wish! If we can hit the 160's, I'll be thrilled this year!
Pages: [
1
Go Up
« previous
next »
Landracing Forum
(Moderator:
