I don't mean to suggest there have been no improvements in bearing technology or lubricants in the past 40 years. Quite the opposite is true, especially with ceramic bearings and synthetic lube.
The discussion was regarding the Green Monster incident in 1966. In 1969 Timken's engineering department specified we use their tapered roller bearings with an oil bath for lubricant on The Blue Flame. This was their choice for a wheel design speed of 750 miles per hour.
The Green Monster spec sheet indicates it weighed 6,500 pounds before the dual rear wheels were used. So, it probably weighed 7,000 pounds in 1966. Empty weight of The Blue Flame was 6,500 pounds also, but with 2,000 pounds of hydrogen peroxide it started with an 8,500 pounds load, and also weighed around 7,000 pounds at 600+ miles per hour.
Granted, the rocket did not add a torque load as did the J-79 on shutdown, but that wasn't the discussion. Also, Art had told me that the bearing problem was the result of grease not provided the necessary lubrication, causing the bearing to seize.
