Now we see how the BUB Speed Trials came about.
These rules changes will cost time and money, and a few records.
So, how does one make an OEM H-D motor go faster without blowing out the bottom end? The 89-inch motor in Rayborn's 265 mph liner was XLR based, XLR being ball bearing mains with ball bearing cams. Last XLR I had blew the right case, I found new cases (this was a long time ago) and went with the "superblend" style bearings the alloy XRs used. Just single row, not the double row on the right side that NC engine builder Johnny Goad (who rebuilt my alloy XR) taught the factory to do. That XLR motor retained ball bearings on the cams. Still running strong as far as I know. But the early stuff is 4 speed. Yawn.
So, for OEM cases, I wonder but what one can take, for example, a 1998 5-speed Sportster/Buell case and use Buell XB flywheels and shafts, but turn the shafts to fit the better bearings. And run needle bearing cams instead of bushings, or ball bearing cams. And spin as far above 8000 rpm as required. For 5 miles twice.
Just thinkin' out loud.
