Author Topic: Spirit of South Dakota Lakester  (Read 305095 times)
Re: Spirit of South Dakota Lakester
« Reply #555 on: November 14, 2013, 06:26:29 PM »
They look good Trent!  :cheers: :cheers: :cheers:
« Reply #556 on: November 14, 2013, 06:44:37 PM »
Thanks PJ! All my pals that saw the first ones today think I need to downsize them to 7/8ths scale, I think they may be right. #1 will go in the tudor or lakester however. I like them.
« Reply #557 on: November 14, 2013, 08:50:37 PM »
 salty, slippery foot with boots on needs a big target.
Offline Captthundarr
  • In line
« Reply #558 on: November 14, 2013, 09:08:35 PM »
Yep looks good Trent, gotta love product development. :cheers:
« Reply #559 on: November 14, 2013, 09:35:13 PM »
Really nice work Trent. Patternmaking is no joke and that result is excellent especially since you're a beginner. Have one on me and I hope you do well with the venture. :cheers:
« Reply #560 on: November 15, 2013, 11:28:23 AM »
Thanks guys, I have several more products in the que, mainly hotrod stuff but I am doing a swin pedal that would work on some race apps.
« Reply #561 on: November 15, 2013, 11:28:56 AM »
Trent, do you have a pivot that's goes with the pedal, center or heel attachment. Or is this something the buyer has to make.Just wondering. :cheers:
« Last Edit: November 15, 2013, 01:20:12 PM by Glen »
« Reply #562 on: November 15, 2013, 12:25:26 PM »
  I used a similar petal on my blown 55 chev gasser in the early sixties also used a hydraulic throttle with it, worked great with easy hookup.
« Reply #563 on: November 15, 2013, 06:54:46 PM »
I have a pivot setup that will work midway as a rocker or on the heel for a bottom pivot. Bolt on steel bracket with oilight bushings. I think I will sell it as a kit so it can be modded to fit the owners needs. May also offer the pedal bare for folks that want to bolt them to an oem style gas pedal.
On a similar note, how are lakesters and liners like Vescos running the throlle from front to the rear engine? I have mine roughed out in my head but would like to compare.
« Reply #564 on: November 15, 2013, 07:29:01 PM »
We  run a Morse cable on both cars, the can be made push or pull and any length. On my dragster and lakester I used hydraulic. both work well for difficult routing. I also used a hydraulic clutch master and slave on the lakester.Hydraulic systems need a bleed port ,like a brake bleeder to get the air out
« Reply #565 on: November 15, 2013, 08:19:40 PM »
Trent, I use a cable on my Tank. Wayno
« Reply #566 on: November 16, 2013, 12:16:13 AM »
Glen, wayno, thanks. I am using a Hydro clutch so I have that covered. Cable in a tube or morse cable was the plan for the throttle.
« Reply #567 on: November 16, 2013, 02:29:28 AM »
The Morse cable or something similar is the way to go if you want to use a cable. With that assembly the toe loop becomes functional because you can push with the cable assembly if for some reason the throttle loses interest in returning.  :roll: :roll: :evil:
« Reply #568 on: November 16, 2013, 12:39:41 PM »
That is what I was thinking PJ!
Offline Roseville Carl
« Reply #569 on: November 16, 2013, 02:24:51 PM »
Pedals look great Trent, keep up the good work!  8-)
"Keep Em Between the Whites"
and yes Virginia the world is indeed Flat
