We have an '07 Tahoe. I ordered it without Flex Fuel -- at no added cost -- because the gas only engine was rated 1 MPG higher highway than the Flex Fuel gas rating. Not much difference, but a difference. And maybe less complicated parts to go wrong. So years later, how would one tell if a vehicle was produced with or without Flex Fuel?
The rule book says
"5.E Production Category
This Category is intended to represent typical transportation vehicles which may be purchased from any automobile dealer"
your vehicle has to "represent" the Vehicle produced. I am sure may vehicles currently running in the production class did not come with the same engine that is currently in tie car or even an engine with the same number of cylinders.
If you read on it talks about at least 500 units being produced etc. The thing i find al little amusing id that you are not allowed to use SCCA or Nascar sheet metal, but you can use a Nascar Engine or cylinder heads.
The way i look at this is that the SCTA is not defining the details of what a production car is, what it includes or what capabilities it does or does not have. If they made 500 of them and you can buy them from any dealer, you are good to go. Unless you want to represent a Flex Fuel car by actually running E85.
Is Bonneville racing stuck in the past? Carburetors and leaded fuel seem to be dominant. Things that have not existed on production cars for 20 years or more. The 1980's seemed to be the low point for production automotive performance. Emissions systems and unleaded gas crippled the power output of the engines of the time. some V8 engines were rated at only 160hp or less. As a racer it made sense to steer clear of inferior fuels and TBI systems that were hard to modify and not designed for performance. But 25 years later Detroit has figured it out, we now have engines like the New ford 5.0 that will produce 1.5 HP/CI right from the factory and on pump gas. The new ford V6 is 305 Hp, and is available in the F150. How many years has it been since you have seen a Full size (US ) pickup with a 6 cylinder?
Forget about E85, What happens when a few smart guys start running a cars with Direct injection? What if it changes the game? Maybe it should be outlawed immediately! It would make all of the old record obsolete. Maybe we should put an asterisk next to records set with direct injection. Just because it works really good, is available on production cars, gives you more performance and less emissions doesn't mean it is what's appropriate for land speed racing.
We hold ourselves to a different standard.
