vtwin dude, or dudette, im at f'in work...i check
in when i can....
wow, need to be able to sit down and put some decent time
into some posts...these shotgun responses are somewhat limited in conveying
my intended meaning...
nrhs/vetwin...im not speculating what the ama will and wont do with respect
to tires at bub......!!!!!
im not against ama as indicated in my praise of much of what they do...!!!!
listen...i was quiet...then simply grew tired of of what i felt was cheap shots
at scta...
ie praising the ama for "taking a wait and see approach" per nrhs....
when i had spent months in communicating with AMA on if i show up
with x tire will it be allowed for x speeds....thats all....in planning for me,
that was desired info, before completing 3000$ in wheels and tires that do
meet the requirement ie lsr 300 mph tires, and appropriate other fees up front, i simply wanted to know what was specifically legal, ie do i spend the money to do lsr tires, can i run like last year, and with scta changes coming down the pipe, i didnt want to assume anything, you should be able to understand that...
some might want to beat around the bush, i dont....
whereas the scta simply took a pro-active approach and initiated a standing
months before the event....with the interest in our safety in mind....(as does ama)..
whether its agreed with or not, its the sanctioning bodies perogative to lay out
the conditions they are comfortable with...and us as racers to follow what we are
comfortable with..within those standards...
seriously nrhs, some of the best folks in lsr are apart of BUB, some of the best people i
know, Rex Svoboda (sp?), Tom Burkland, Denis Manning etc all i consider good friends..i wouldnt for once want to encourage any ill thoughts toward them...
to answer nrhs, yes lsr goodyear tires such as the 2282 and 2284 have 300 mph ratings per manufacturer...
vetwin..i would choose zr dot or race spec, next runs opting for race spec zr radials as well as
continuing learning about the lsr 300 mph tires i ran at sw...trying to make wos and or wf..would REALLY like to meet you and discuss these issues, in a practical real world manner, actually at the venue of use
with the tires we speak of....
