Author Topic: XXO/BVGC '38 Chevy Coupe Build  (Read 1031944 times)
Re: XXO/BVGC '38 Chevy Coupe Build
« Reply #570 on: August 22, 2011, 10:56:03 PM »
Easier view.
« Reply #571 on: August 23, 2011, 12:43:14 AM »
I'm still trying to figure the best place to relocate the front shocks, to get them inside of the front sheet metal.
Buddy -
Have you considered lever shocks?  The rear shocks on an MGB or a Midget bolt inside the frame and have a very low profile link.  Parts # 1 and # 2 from the Moss catalogue -
http://www.mossmotors.com/Shop/ViewProducts.aspx?PlateIndexID=29025
I could send you one or two (or a dozen, for that matter) if you wanted to trial fit them.
Drop me a PM if you're interested.
Offline Ron Gibson
« Reply #572 on: August 23, 2011, 09:24:59 AM »
Stan
Still trying to figure out if you are talking about hard metal parts or Tony's new avatar. LOL
Ron
Offline jimmy six
« Reply #573 on: August 23, 2011, 09:58:31 AM »
38 f....I too wonder what the excitment is after 37 years of off and on going to the salt especially for those who don't have or drive a car/bike. (it would be easier to get a room too)
On the tranny I keep the arm on the shifter even tho there is no gear in the transmission so the shifter works properly for the spacing. During an inspection once I saw a metal strap fron the arm on the trans to a spot on the side cover. I thought that was an easy fix. ...Good luck and hopre to see you in October...JD
Offline 38flattie
« Reply #574 on: August 23, 2011, 02:18:18 PM »
Chris, lever shocks may work, depending on if they can be made VERY stiff. I've got 12/12 shocks on it now, for very little movement. I'm not a big fan of very much suspension movement, at the speeds the car will run.
Jimmy, we're thrashing again, to make WF. I truly hope to chat with you there!
I've figured out that when Tony posts, views on that thread go up about a zillion%. I'm sure this is because of his valuable input, and not because of his avatar! :evil:
« Last Edit: August 23, 2011, 02:24:48 PM by 38flattie »
http://youtu.be/89rVb497_4c
« Reply #575 on: August 23, 2011, 03:42:29 PM »
Buddy -
Moss offers a performance metering valve - a true bolt-on upgrade.  Additionally, Apple hydraulics rebuilds these things all the time, and can set them up probably just about any way you'd need them.  I went with the "Heavy Duty" rebuild option on mine.
http://www.applehydraulics.com/shocks.htm
Offline RichFox
« Reply #576 on: August 23, 2011, 03:54:21 PM »
I have rear lever shocks in my For Sale Vega. As I remember the heaver viscosity oil the stiffer the shock action. Also, if you came home with a brand new Craftsman 1/2 drive ratchet, It was mine.
« Reply #577 on: August 23, 2011, 07:39:43 PM »
Very true - I loaded up the MGB shocks with a fairly heavy marine grade Castrol hydraulic oil, and while it rides like a lumber wagon, the thing cuts a corner like a razor.  Probably not the best thing to do for a street car, but on the flats, I'd think you'd be golden.
Offline 38flattie
« Reply #578 on: August 23, 2011, 08:50:29 PM »
Thanks Chris and Rich.
Rich, I'll as Dale about the ratchet. If he doesn't have it, I'll send you one, because I know we used it! Please send me your address.
Chris, that sure sounds like that may be the way to go. I looked, but I couldn't find the Moss  performance metering valve - do you have a link?
I'll shoot you a PM!
« Reply #579 on: August 23, 2011, 11:52:53 PM »
« Reply #580 on: August 24, 2011, 12:00:27 AM »
MM;
"I am not a number, I am a free man!"  .....from "The Prisoner", right?
Regards, Neil   (San Deigo, CA)
« Reply #581 on: August 24, 2011, 12:04:35 AM »
MM;
:wink:  I've got the whole set on DVD. :-D
Always wanted a Lotus 7 . . .
« Reply #582 on: August 24, 2011, 03:34:06 AM »
Build a Locost and get the same experience for a lot less than the real thing. Most likely a better car too. :-D :-D :-D
« Reply #583 on: August 24, 2011, 05:32:48 AM »
The roadster guys 'ave a neat trick--they mount flat bar that attaches behind the front axle in its wind shadow, and pivitos on the chassis behind the grill shell and a spring shock mounts vertically in the center of the car left side springs the right side ect.
Offline Richard 2
  • 2 Richards Racing
« Reply #584 on: August 24, 2011, 11:58:06 AM »
[/quote
Would like to see a picture of this set-up if any one has one.
Richard
4 cylinder Esslinger
Could of had a V8
