I asked Tom Evans to define a race tire so that I can purchase new legal tires. His response today was:
-racing tires
-road racing tires
-DOT road racing tires
-DOT racing tires
I was also concerned if shaving was permitted and yes it is, if done in a safe manner.
I encourage all of you who are affected by the rule change to contact Tom, Van and Lee, they were quick to respond to my questions.
Cheers,
Scott
OK,let the confusion continue. Dean says "a tire with no DOT #'s is what your looking for(so a tire with a NHS stamp),then according to the quote,Tom Evans says a "DOT race tire" is OK,which IS going to have a DOT #
. Shaving is OK,but what about grooving? Don't see a slick getting much bite at EM.
And bak139 has made a valid point about the compound. Even the "hardest" NHS tire is soft by normal standards and is designed to be on a sub 400lbs bike with a 160lbs rider on its back,not a 550lbs 'Busa or ZX12/14 with a cornfed pilot and 80lbs of ballast onboard. Especially when you check the recommended pressures which are usually in the low 20's If those parameters are not taken into consideration this new rule is probably going to cause more problems than it solves. Unfortunately it'll probably take a spectacular failure of a 'safe' tire to get recognition of this fact. As far as a racing tire being built to a higher standard,what do you think a tire mfg is more worried about-a tire failing under race conditions,or a tire failing on an open class bike out on the highway with a potential litigant on the back?
Look,I'm like everybody else,I have a family that really needs me to make it home from a meet to go to work and pay the mortgage,but I believe that this ruling was a little rushed without adequate undertanding of what the solution was going to be. Yes,with bikes now in direct view if a 300mph pass,tires are a huge issue. But for bikes under 225 the old rule has gotten everybody home. Tires aren't like making a metal chainguard or adding a steering damper,we can't "make" a tire in order to comply.
Unless someone like M/T Tire(they build DOT legal drag tires for sub 7 second bikes) decides to do something for us the only logical progression(if 'safety' is the cause) is to ban bikes over 200 until a purpose built tire is available. And since by anyones admission that isn't going to happen,looks like bike racing is over
BTW,If I can get my hands on some,looks like the Dunlop N-Tec slick with the Daytona compound is the best bet.
