Uh-oh....watch out!
I hope Kents not thinking of a "J.D. Tibbets" tow with his electric bike!
J.D. was a legend in the desert....he'd carry a tow rope, and give you a tug if you broke down. Trouble was, he could tow you faster than you knew how to ride!! None of us ever fell for that twice, lemee tell ya'.
Seriously, though, there are 18" ZR rated tires (front tire from ST1300 for example), but I haven't found 19" ZR rated. I'm changing the front end on an MPS bike to get 17" and go around that problem. If you go M class, could maybe convert that thing to chain (theres always a way), use the .020" cleanup allowance, and get into 650 Blown class (though I'm not completely sure that's legal, maybe the engine has to start out as less than class limit, and cleanup takes it over). You could be looking at 153 in M-BG 650. If you can make and handle the boost, it could be possible!
Or...you could take out one piston, rod, etc. and run 500cc (you'd be 489cc) where there is no M-BG and MPS-BG is 82 mph! Just get it running good, put on current tire (won't have to be ZR against an open record or 82 mph), and come on out! It'll shake, but it's only a couple miles.
You shouldn't listen to me.....I'm bad for weird projects, and it's not always a pleasant experience!
JimL
