Ed and I do differant things on shut off. I like to back out, idle for a while, click off, coast up to a mile or so and then throw the high speed chute. Ed likes to immediately throw out the chute, not necessarily drive into it but get it ou quick. Both work really fine on the Danny Boy. We spentr a lot of time setting up the chutes, both the high speed and what we call the "oh s**t chute. They have never failed us. Well I guess nI have to clarify that, we have had 2 failures in 25 years. One was at WOS when we were running a super trick Kevlar cord, supposedly good for 25000 lbs pull. It failed at the worst possible time. What we discovered was that if there was even the slightest twist in the flat cord, it would break. Ed was blown off course, hit the timing battery, pulled the chute, jerked the wheel, and went on his head. The only other failure that we have had was in around '95". I was doing a check out pass, was half way through the last mile when I felt a bang and quick decelaration. The car ran straight and continued to accelarate fine. I said to myself-no there is a problem here. Went to neutral, coasted for a while, hit the high speed chute, many times but no results. By this time I was at the 6 and 1/2. Hit the "oh s**t chute with the same results. By then I was past the drug portion of the course. We had driven in the prerace inspection to the 10 mile to check all things out. Glad we did that and will always do that, see just how far we can go if necessary. got stopped with no problem at about the 9 mile but it was not fun. What happened was that in the 4, we hit a very large hole, it bounced the chutes out of the tubes and unfortunately the tether point grenaded. Trust me me have since made sure that can not happen again. Anyway, wild rides can happen.
rht
