Hey,
I'm new here, so I hope you'll pardon the ignorance. I was hoping to come up for the World Finals, get my first look at the salt, and talk to folks there. But now that doesn't sound likely, so if its alright, I'd like to ask a few things here.
I want to take a street legal 2004 GTO to 200+. Not especially much over that, but to 201, 205, whatever. Worse, I really want it to be a streetable car, my daily driver. So to me that means a Turbo, methanol injection, maybe 8PSI on the LS1, around 550HP, should get us in the ballpark, while still leaving it streetable.
The first issue I ran into was tires. I've read a lot of discussion on here, but its left me confused. Will I be allowed to run my Goodyear F1 GS-D3 Y rated tires? I'll never get the GY ELSs under the car without replacing the rotors (which are too big), big pain and expense. And it sounds like there are really no other alternatives.
General views on carbon fiber driveshafts? The factory GTO one small, two-piece, and supposedly a real weak link when HP numbers start growing.
Think I'll need extra fluid radiators? Transmission (its an auto), oil, something else? I know its recommended to have an extra half-quart of oil for high speed running.
I figured replacing the pinion gear with a 3.07, the overdrive is 0.7, the tires are 25.68 or so tall, so around 5600 rpm for 200, which should be right in the wheelhouse for a turbo LS1. Sound believable?
Like others, I'd likely come up to run the 130 and 150 clubs first, crawling around other folks' cars between runs, as I'm sure there is only a 100 or so things I haven't even thought about yet.
Still gotta order my rulebook. I was hoping to pick one up in a couple weeks in person, oh well.
I ran the Texas Mile last spring, first GTO to do it, turned consistent 145-150 speeds. Only made 20 or so runs, just drove it in circles, the car did it with ease, in stone stock trim, no turbo. Likely around 165-170 factory top end. Its that next 30-35 that is going to get expensive.
Anyway, wish the moron luck, any opinions, suggestions, or lectures welcome.
