I have always been curious if there has been any testing done regarding how a wind tunnell (air being forced past a stagnant object) compares to an actual object forcing itself through stagnant air?
Good question. The NASCAR Teams spend a lot of time performing what we call straight line testing or coast down testing to validate what they learn in the wind tunnel. This is very difficult to do right because of the number of variables involved that must be kept track of to compare changes on the car. In a wind tunnel we control many factors but in straight line or coast down testing you are at the mercy of the natural conditions such as wind, wind angle, temperature, and pressure that are constantly changing throughout the day. The car needs to also be highly instrumented as well to keep track of variables such as temps, heights, ground speed, relative wind speed, yaw angle (relative to wind), any incline or decline in surface, etc…
This type of testing has been going on for years and teams do correlate what they see in the wind tunnel to the track. You need to be smart enough to know what you are correlating, to the wind tunnel used for correlation. Example: If you have an underbody change or inner fender change you need to be correlating to a wind tunnel with boundary layer control on the floor and rotating wheels (such as AeroDyn or Wind Shear). If it is an over body change (nose, hood, wing, spoiler) something like A2 could be used for the correlation.
I posted a video about a year ago but will post it again. The video only talks about them testing and not so much of what’s involved. You will not find a good video because teams are tight lipped about the procedures used for any type of testing or R&D.
NASCAR straight line testhttp://www.youtube.com/watch?v=qM11-Qm5QOQTo illustrate how hard it is to get adequate data, notice how the engineer says they get 12 coast downs per outing. That means that it takes 12 coast downs for one change on the car (think fuel, tire costs, time, $$). They have to do this because of all the factors involved and seeing how consistent they can detect the change. In a wind tunnel one change can take minutes to know the answer. So teams will test a large number of things in the tunnel and then narrow it down to the changes that worked to then validate in a straight line test.
