For my 53 Studebaker (under Build Diaries) From what I read I am required to have roof rails and those rails need to be a max of 3/4" tall. If that is the case I guess I should make them the maximum height of 3/4" ??
Then where do I put them ? I know,,, silly on the roof would be a good place,,, but seriously,,,should they run from the the windshield back to the back glass ? then how far apart.. side to side,, as far out towards the doors or what ?
I was thinking of using .060 aluminum 1.5" wide and bending it to make 90 degree angle,,, 3/4" vertical rail and the other 3/4" flat attached Rivet ? or Bolted? to the Roof ...
Thanks
Charles
