Author Topic: spring weights vs. narrowed front ends  (Read 18170 times)
Re: spring weights vs. narrowed front ends
« Reply #15 on: October 27, 2015, 12:21:23 PM »
Jonny, it may have been cross winds, wheel spin or other.
You obviously know how the rotary delivers its power?.
Very different to 4 strokes!!!.
Maybe the problem isn't as bad as you think.
Check the shocks, anti roll bar links and other related components too.
Hopefully it's a small easy to sort out problem.
Just my 2c but the other advice you got is good. :cheers:
« Reply #16 on: October 27, 2015, 01:04:28 PM »
Did he mention this crashed at Bonneville.
« Reply #17 on: October 27, 2015, 02:44:45 PM »
Mike, this is a world you are entering into with your liner. You have to eliminate body roll to expect a three point vehicle to accurately respond to steering input's at speed without lag that can evolve into over input from the driver.
I don't know if that was the case with his crash but it can be a real problem with any vehicle at speed & is exaggerated with a three pointer.
« Last Edit: October 27, 2015, 03:00:17 PM by kiwi belly tank »
« Reply #18 on: October 28, 2015, 01:10:44 AM »
The basic problem with 3-wheel vehicles is that they have zero roll resistance on one end and non-zero at the other. Whether it is a 'liner or an old Morgan, handling on a 3-wheel vehicle is tricky in anything but a straight line.
« Reply #19 on: October 28, 2015, 03:02:02 AM »
Thanks for that guys. :wink:
« Reply #20 on: October 28, 2015, 07:40:31 AM »
When Higginbotham got his balanced "right"--- I could drive it with very light pressure of on my thumb and a finger tip as we were going up through the gears.  His was solid in the front and rear but he could change the frt. slightly with shims.
