Latest deal is to find that all the line boring and such put the crank centerline .032 closer (as best as I can measure) to the cam then the Bros. had in mind. So the new cam gear doesn't fit. I am now waiting on the gear cutter to make it smaller. The rings are much closer to the deck than I had in mind. Right now I think I'll run it. I am tired of "Do Overs" Besides, I'll always have time to do it over later, right?. Got all the internal oil lines done. Head is done. Gasket is done. I was going to work on the front cover and front of the pan when I tried putting the cam gear on. So that's the next big thing. and last I think. The blowshield is drilled for the Dodge.I need to make a rear seal holder. Buy a SBF flywheel. Put it in the car. Make headers.
