We are trying to improve on the center of pressure on Hooley's Stude.
The rule (4.CC.5 Skirts) says:
Streamling devices.........................thick. The skirt shall be in a single plane, mounted to the bottom of the body but cannot modify the contour of the body. The skirt may extend from the centerline of the front axle to a vertical plane at the rearmost point of the original bodyline.We don't want to do anything between the front and rear axle, just behind the rear axle where the pan slopes up.
Does the cardboard mockup below the rear quarter panel in the picture above meet the requirements to be considered a skirt?
Does it have to be parallel with the ground on the bottom?
Can it be any size vertical we want as long as it isn't on the ground and doesn't extend past the rear of the car?
The car runs Competition Coupe.
