Author Topic: Class help  (Read 3023 times)
Offline mhuppertz
Class help
« on: April 17, 2009, 08:03:33 PM »
We want to prep a Honda CT90 for a run at speed week. Can anyone help me with class designation? it will be under 100cc (5.5 ci), run in stock body form naturally aspirated or superchareged.
Thanks!
Mark
Re: Class help
« Reply #1 on: April 17, 2009, 08:50:36 PM »
Got a Rule Book?  The answer (along with a lot of other things you need to know) is probably there.  See the SCTA-BNI.org website.
Re: Class help
« Reply #2 on: April 17, 2009, 10:22:42 PM »
CT90 isn't that the designation for a Honda Trail 90? The motor has an OHC so in stock form normally aspirated you would run in 100cc P-P. Current record at Bonneville for 100cc P-P, is held by Katy Gassaway, type of bike is a Derbi, date record set 8/03, Record is 82.846 mph. Hope this helps.
McRat
Re: Class help
« Reply #3 on: April 17, 2009, 10:41:52 PM »
That is curious.  The 100cc P-PP (Production chassis, production pushrod engine) record says Honda.
When did Honda make a pushrod minibike engine?
If I were hunting a production powerplant for a 100cc bike, I'd look at either the Suzuki or Kawasaki rotary valve two strokes.  With the right massaging, you can make some pretty good high RPM power with a rotary valve.
Re: Class help
« Reply #4 on: April 17, 2009, 11:07:55 PM »
The 87cc PUSHROD HONDA C200 1964.
McRat
Re: Class help
« Reply #5 on: April 17, 2009, 11:53:14 PM »
Huh.  Looks just the OHC engine.  IIRC, my 305cc Honda Scrambler was OHC, and 1963-64'ish.  It had centifugal spark advance and a centifugal oil filter.  I'll admit I never paid a bunch of attention to the Honda 90's and their kin.
