Author Topic: 750cc pushrod bike build  (Read 69967 times)
Offline Rchop
    • FRS Engineering
Re: 750cc pushrod bike build
« Reply #195 on: May 27, 2010, 10:53:47 AM »
Scott Stites (isiahstites) has started a new CNC business and he made my turbo flanges for me. Here are some pics of the machining process...
www.frsengineering.com
#4836 A-PBF 750cc(complete)
#765 A/G 650cc
Offline 55chevr
« Reply #196 on: May 30, 2010, 10:16:28 AM »
Randy,
Can Scott cut out triple trees with his machine?
Offline isiahstites
« Reply #197 on: May 30, 2010, 11:09:22 AM »
Randy,
Joe I can make quite a bit. Some things are more complicated than others. I am working on a design for a set of triple trees right now.
Scott
Offline 55chevr
« Reply #198 on: May 30, 2010, 12:22:06 PM »
Let me know when you are ready ... I want to make a top tree for S1 Buell ... you might even still have one from your donor Buell ...
Offline Rchop
    • FRS Engineering
« Reply #199 on: June 11, 2010, 12:55:36 PM »
Turbo installation is complete. The biggest problem was the oiling system since the resevoir is higher than the turbo. I think I finally solved the problem with an inline ball check valve that I will install just before the turbo oil connection. The valve has about 2 lbs of seat pressure that should stop oil from draining into the turbo at rest.
http://www.frsengineering.com/pp162.JPG
During test runs on the country road in front of the house, I was able to get it up to about 5300 rpms in 3rd gear with 7lbs of boost before I was going too fast for the street and and my A/F was going over 15. If I can get the fuel mapping right, this should work well.
http://www.frsengineering.com/pp160.JPG
http://www.frsengineering.com/pp161.JPG
#765 A/G 650cc
Offline Rchop
    • FRS Engineering
« Reply #200 on: July 15, 2010, 04:10:27 PM »
New turbo installation is well underway. Exhaust pipes have been cut and reassembled with a new transition to a T-25 inlet flange...
http://www.frsengineering.com/pp163.JPG
The shaft was broken on the old turbo and I don't know exactly what caused the failure, so I made changes that could account for multiple reasons. These include a larger turbo and a Blow Off Valve on the plenum. I'm hoping the American made Garrett turbo will solve the Chinese bearing failure if that was the major issue.
http://www.frsengineering.com/pp164.JPG
I just have to mount the pipes and turbo and then weld and wrap the new dump pipe. I'm adding a v-band connector to the end of the dump pipe so I can change ends when running faired or un-faired.
#765 A/G 650cc
Offline 1212FBGS
    • http://www.motobody.com
« Reply #201 on: July 15, 2010, 04:29:42 PM »
ummmm..... is that bov mounted in the right direction?
kr
Offline Rchop
    • FRS Engineering
« Reply #202 on: July 15, 2010, 04:34:00 PM »
yes, the flange that is welded to the plenum has a curved base that was sized to weld onto the turbo inlet pipe, but I didn't have enough room on the pipe.
« Last Edit: July 15, 2010, 04:37:05 PM by Rchop »
#765 A/G 650cc
Offline 1212FBGS
« Reply #203 on: July 15, 2010, 04:53:16 PM »
isnt the exhaust of a BOV usually on the side and the intake on the bottom?
kr
Offline Jasontmc
« Reply #204 on: July 15, 2010, 05:44:05 PM »
The BOV is mounted correctly.
 Look at the vacuum port at the top of the BOV ,   when the throttle is chopped the vacuum is applied to the top of the diaphragm and the boost px moves the BOV slide up against the spring and allows the boost  to vent to atmosphere.
Offline Rchop
    • FRS Engineering
« Reply #205 on: July 15, 2010, 06:07:56 PM »
kr
I saw them in all different configurations Kent. I ordered this one because I wanted a more compact installation.
#765 A/G 650cc
« Reply #206 on: July 17, 2010, 12:42:56 AM »
Will you be putting a bigger air filter on that bike?  The restriction from the small filter might not be a problem, the turbo suction can handle that.  It is the possibility of high vacuum pulling dirt through the filter.
Offline Rchop
    • FRS Engineering
« Reply #207 on: July 17, 2010, 09:42:53 AM »
I want to keep the profile as small as possible since it's sticking right out in the airstream. With the lower HP of the 750cc, every little bit helps. The new filter for this turbo is about the same size and I have always gotten good performance from K&N's.
#765 A/G 650cc
Offline AHG
« Reply #208 on: July 17, 2010, 10:06:51 AM »
I Have really enjoyed seeing your machine come together.
Well thought out, and nicely engineered; from the chassis to the engine.
Best of luck, and God bless when it reaches the salt.  :-)
Drew Gatewood
~ I CAN COUNT MY LIFE ON ONE HAND ~
Faith, Family, Friends, & Fast Motorcycles
Offline Rchop
    • FRS Engineering
« Reply #209 on: July 17, 2010, 10:16:02 AM »
Thanks Drew, I appreciate the encouragement.
#765 A/G 650cc
