Bigmellon you must have the DY150 --it has a 150cc non pushrod motor--if you bolt on a blower (turbo) that would put you in the bg or bf class (blown gas -blown fuel ) and the 175cc class so in the modified class you could run m-bg or m-bf if you add streamlining in front of the rider you would run in the mps-bg or mps-bf ( modified partially streamlined --blown gas or fuel ). There are some things you can do that you cant do in production ---you can extend the wheelbase 10% over OEM----original lights, instruments, fender, gas and oil tank, seat,forks, swingarm, shocks, brakes and wheels are optional footrests have to be 6 inches in front of the rear axle you have to have a chain guard and there are some other rules about streamlining, exhaust and fenders but that should pretty much give you an idea of what you are in for what you really need to do is buy a rule book an '09 preferably but they are not out yet an '08 if you can find one and the rule changes for '09 are posted on the scta website hope this helps---------mellon you would run in the 175cc class---if you bore or stroke the engine to 175cc you are still allowed a .020 in. overbore over the 175cc limit but cant claim the .020 in. bore to move you into the next higher class -willie
willie buchta
