Still waiting on the crank.....
Because its the weekend I got a little stir crazy so I decided to learn head porting.
Here is a list of things you will need if you decide to try this yourself:
Die grinder
carbide rasps (a few different sizes and lengths, their expensive...get ready to drop about 25-30 per, a 4”X.5 flame tip will get ya real close )
cylinder flap wheels (I am using 80 and 120s)
depth gauge (only needed to be accurate to the 1/16th, so you can use another method for measuring)
snap gauges
a reference head or really good map (I recommend using a reference head but I made a map that you can have if you feel froggy and want to jump).
A good light (didnt have but wished I did)
bench to work on at a height that is comfortable to work on......
The head I am using for a reference head is a stage 3 big valve. This is not a CNC done head but was hand ported by what many consider to be a master and was flow/velocity tested. This head is on our big bore motor (1507) and made 242 WHP without adders so it clearly is doing a good job.
Note that I did not remove the valves (no valve spring compressor) and did not finish the job yet....I will be having the exhaust seats enlarged for a +1mm and SS valves installed. Once the head is milled for the larger exhaust valves I will finish from the other side and blend the step made by milling process.
I can not really do any more until the head is milled for the larger valves and the old ones are removed.
With that....
I started off by making a cap to keep excess bits from getting in the head....sort of a waste of time because the thing will be cleaned anyway.
Here you can see what some of the fuss is about. The head casting is rough.
Here is a measurement of the reference head (this is actually what I called "level 2" measurement.
You need to be very aware that these ports are not round...they are in fact oval so you will need to take measurements in X,Y and Z.
I did however note that there were equal amounts of stock removed from each side of the port and all ports were close to identical, so you dont have to worry about thatIn this pic you can see that at a depth of 1.5" my snap gauge measured 1.85 for the "X" (it was considerably less for the Y and only about a 3/32 more than OEM (less than 1/16th per side on the top and bottom removed and really just enough to clean and polish) but also note that I haven’t got past the valve seat yet and this may change in the future).
My first measurement was about 1/8th larger than OEM from the end of the port to about 1". Use your grinder to make equal depth grooves on either side of the port until you snap gauge fits. These grooves will let you meter how much stock you are removing from each side and how deep.
Once you establish how much stock will be removed and how deep you can blend the groove in by progressively removing material on either side of the groove until you can not discern it from the surrounding surface. Remember that there is very little material removed from the top and bottom (Y) of the port but in truth quite a bit came off the sides.
I recommend taking your measurement steps about every inch.
Its hard to tell but this is about 3" into the port. You can see the "level 3" measurement groove.
Here is the flap wheel I use to remove the chatter caused by the carbide rasp.
The thing looks big in the pic but in reality is only about .75".
I only hit one port for a minute to give you an idea....I will be much more precise once I get the other side done.
Here you can see a good bit of the chatter is removed and are starting to look pretty good.
I will admit that so far it hasnt been difficult to do this but take into consideration that I am copying note for note the work that was vested in learning the places to remove material and how to shape the port for optimum performance.
If you got the hotnuts I would say that porting your own head is very doable but remember without using a reference head or map you will be almost guaranteed you will find an oil/water passage if you want to do anything other than just cleaning it up.
